Low Fuel Light...
Old 04-16-2012 | 09:37 AM
VTArrrgh!'s Avatar
The Pirate Sportbiker
VTArrrgh! is on a distinguished road
Low Fuel Light...
Hey, gang - I'm new to the forum and to the Super Hawk, though I've spent my whole adult life on the back of a Honda. Anyway, I bought a '98 a few months ago and found out the hard way the fuel light doesn't work. I did a little research and found out how to test the fuel sender to see if it's bad (which I assume it is). Someone made a comment about the sending units on the '98 models that leads me to believe this was a very common malfunction on the earlier bikes, correct? I looked for a new sending unit online and could not find a part number, which means I'd have to find a replacement on eBay or the like, right?
Any help would be appreciated!
I'm in the process of building my own manual CCTs as well, as I did on the F3 I had prior to this bike...
Old 04-16-2012 | 09:40 AM
Wicky's Avatar
check the bulb?
Old 04-16-2012 | 09:47 AM
VTArrrgh!'s Avatar
I didn't. I was going to run some jumpers to it, but I couldn't find my wire strippers. How likely is it that *that* is the problem? Really stupid question: Is it easier to replace than it looks?
Old 04-16-2012 | 09:55 AM
Wicky's Avatar
undo 3 bolts - tilt instrument console forward - take out bulb - get replacement
www.vtr1000.org • View topic - Fuel sensor - 1997 model VTR
Old 04-16-2012 | 10:19 AM
aja's Avatar
aja
If its anything like the instrument lights, its a matter of 3 bolts holding the column, then just flip it over and pull out the lights
However, I have a 98 that the light doesn't work on also. I have checked the manual and it doesn't say what type of bulb it is, and when I had the column pulled off I didn't see a spot for a bulb. If anyone knows what the bulb number is is appreciate it. I'll be pulling the cluster off tonight and will post what it is of no one else does.
Old 04-16-2012 | 10:50 AM
Wicky's Avatar
Pg 319 19-6 In the downloadable PDF Honda VTR1000F Service manual
http://f.cl.ly/items/0n0S1q3g3e2e1d3...r-fuelbulb.jpg
Pg 330 19-7 LOW FUEL INDICATOR/FUEL RESERVE SENSOR
SYSTEM INSPECTION
VTR microfiche (BULB capless 12V 1.7W) 34909-KW3-003
http://www.ronayers.com/Fiche/TypeID...EDOMETER_98-00
http://www.davidsilverspares.co.uk/V...97/part_24868/
http://www.wemoto.com/parts/picture/MS-OL2820K/
Old 04-16-2012 | 11:34 AM
tomzxt's Avatar
Light Cycle Expert
Before wasting your time removing the gauges just take your seat off and use the method in this article I found using the search function a while back. https://www.superhawkforum.com/forum...el-light-7189/
This will cause your bulb to turn on letting you know if it works. If it does it's your sender that is bad like most of ours.
Old 04-16-2012 | 11:45 AM
aja's Avatar
aja
Ya I've done the test, no light at all.
Wicky, I know that is the replacement bulb for the instrument lights, but the gas light is much smaller and I don't remember seeing a rubber boot where it should be. To avoid confusion, does the first gen cluster use the same type of bulb for the low fuel light?
Old 04-16-2012 | 12:06 PM
Wicky's Avatar
mmmm I could have sent you all on a goose hunt
The low fuel indicator seems to have a separate bit - the dotted arrowed line on the illustration continues past the usual suspects
Old 04-16-2012 | 12:40 PM
saige's Avatar
the boss
there is no bulb you can get to,you have to take the face of the guages off to get to it.i would test it that way first to determine if it is blown.
its a l.e.d. light that is soldered.
aja's Avatar
aja
I see. I read on some of the firestorm pages that it is an led, ill tear into it later and see what I find. Thanks anyways.
Old 04-17-2012 | 06:10 PM
aja's Avatar
aja
Alright well it is one led. I retested with a paper clip and the light comes on when I jump the clip. The manual says to replace the sensor when this happens. Ny question is it possible to manipulate the float from the fill hole? What i can see is a small bar with a yellow wire wrapped around it, and one fatter one thy I think is just a vent tube. I'm tryimg to figure out if mine is just jammed before I replace it.
Old 04-17-2012 | 07:30 PM
ascothawk's Avatar
ascothawk is on a distinguished road
I just replaced the sensor on my 98. It's not a float. On the end of the rod is a thermal switch that when is submerged stays cool (open switch-no light),when the fuel level drops it heats up closing the switch (light on). I got mine at Service Honda for about $30.00
Old 04-17-2012 | 09:42 PM
aja's Avatar
aja
Hmm. Page 360 (19-17) of the manual says there is a float. Is it the entire sensor that has to be replaced or did you just change the switch?
Old 04-17-2012 | 09:52 PM
aja's Avatar
aja
I was mistaken, it says 2000 and up have a float.
Old 05-12-2012 | 08:24 PM
VTArrrgh!'s Avatar
Light works like a charm, so it looks like I'm looking at a new sending unit (or a used one). Unless - is there something that can be fixed? A loose or broken wire perhaps?
Old 05-12-2012 | 09:48 PM
Hiere is a related question after an hour of reading on fuel lights. If I remove the dash and connect an LED to the fuel wires, will (should) it light at low fuel or is there circuitry in the dash that does it?
I just replaced the dash but still want the fuel light to come on. (thus the LED bulb)
Old 05-13-2012 | 07:12 AM
RWhisen's Avatar
Former Superchicken Owner
LEDs must be connected the correct way, the diagram may be labelled a or + for anode and k or - for cathode (yes, it really is k, not c, for cathode!). The cathode is the short lead and there may be a slight flat on the body of round LEDs. If you can see inside the LED the cathode is the larger electrode (but this is not an official identification method). LEDs can be damaged by heat when soldering, but the risk is small unless you are very slow.
Never connect an LED directly to a battery or power supply! It will be destroyed almost instantly because too much current will pass through and burn it out. LEDs must have a resistor in series to limit the current to a safe value, for quick testing purposes a 1k resistor is suitable for most LEDs if your supply voltage is 12V or less.
Old 05-13-2012 | 08:43 AM
BeerHunter's Avatar
Slacker
The wiring should always be examined for damage prior to condemning any suspected bad part.
Old 05-13-2012 | 10:27 AM
Is the plug at the back of the tank plugged in? No plugged in = No light.
Old 05-13-2012 | 10:39 AM
Yes for me the tank plug is plugged. I suspect that fake gas with all the ethanol filler isnt doing anyone any favors.
I know many BMW fuel sensors are failing for this reason.
ima98chickenhawk
04-21-2014 02:57 PM
Jetfever
05-13-2011 04:23 PM
maverick
05-17-2010 08:06 PM
Jetfever
07-07-2005 11:58 PM
