A little bit rich.
#31
Well it has been a long time, so I'm going from memory but the problem is that the you can't get the screws to engage in the airbox because it will be held too far apart. The K&N has a much larger lip on it than the stock filter and if you try to leave the o-rings in place there will be a huge gap between the bottom and top of the airbox.
#32
You might want to hold off on putting that #50 back in until after seeing where the needle is at now. It could be that raising the needle will make it run properly.
The fix for the K&N is to replace it with a stock filter, which is a dealer only item. It will last maybe 12k miles or so. Check the price on replacements.
EDIT - Carbs were a touch out of sync. My new gauge works great. Idles smoother with those needles backed in a bit but I still have the occasional pop through the airbox.
#34
Does the k&n filter disrupt the idle at all? Seems to me if that filter did have a negitive effect it would be in the mid-high range.
#35
Somewhere, could be here, I read the K&N is the same size as some car but the poster didn't say which car. He only said it tool awhile to find it going through boxes at the autopart store. I'd rather have something other then K&N anyways. Do you know which filter fits the K&N hole?
#36
While you did say the idle was lean with the 48s you never did say why you though this and with as large of mains as you have it is kind of hard to understand but it's all good and the plugs will still be black when you pull them the next time.
Other than that it kind of looks like you need to reinvent the wheel for yourself, so have fun and let us know if you do ever get it right.
#37
Ok, a little off-thread at this point, but I'm running rich and the bike is almost bone-stock. I am the only owner on my bike.
I have a '98, bought off the showroom floor that year.
Popped on decel, but I thought it was kinda fun even when it stalled a couple times.
Lucky I'm reflexed to grab a handful of clutch when it feels/sounds like something bad is about to happen.
I have 15K miles. The carbs have never been monkeyd with.
I seldom get more than 30 mpg unless I'm riding slow, tight twisties with lots of 3rd-gear corners where I want torque to power out the exit. (Unfortunately the good roads around me have lots of blind hills and corners in a heavy agriculture region. Can you say "oh no, hay truck!"
Here's the deal.
Sometime during the first year I owned her I did a partial bypass on the exhaust baffles by drilling holes around the center exhaust outlet. (I think it's 8 holes per can, about 1/2" each hole, can't go look right now.) Mission accomplished, it didn't sound like a sewing machine any more.
After that I would expect it to be running lean.
I haven't replaced the original air filter yet, but again, I would expect it to be running lean.
I had some trouble with cold weather starting from when the bike was new., so I adjusted the choke out a little after I'd ridden her for a couple of years.
That could have been the beginning of all of it.
I changed the plugs for the first time a couple of years ago around 10K miles.
They were basic black, but I've owned mostly two-strokes in my life. They weren't attrociously dirty or gunky, and nothing came off with a wire brush, so I didn't freak.
Lately I've noticed soot around the exhaust outlets, but I'm embarrassed to say that I'm not sure when it started.
Last summer, I had a short period where she wouldn't run at low rpms without half-choke, so I thought "sitting around a lot with gas in the tank and carbs a lot of the time, hope I don't have to have it taken apart and cleaned."
The only carbs I've ever taken apart myself were on my old Kawasaki S2A in high school, and that didn't go well.
I've tried to always use fuel stabilizer if I think she's going to be sitting for a while.
Somebody on the forum suggested Sea Foam, so I ran a can of that through it over the course of several rides and the problem went away.
OK, this year I've noticed my powerband isn't coming "on the pipe" as low as it has in the past.
Up until lately 3000rpm in 6th gear was an indicated 55mph and I could do a full roll-on from there.
Now she doesn't doesn't want to pull below 3100. Not a big deal, but a PIA in my book.
Ideas?
Here's the deal.
Ideas?
#39
By the photos of the plugs they look almost new, that is unless you cleaned them before you took the pic in the first post. Even if they are old the bike is still way rich, those plugs are so black they almost look wet.
It changes the air flow everywhere. The last 2 questions for you would be do you have the rubber blocks that go under the filer installed? If so do you also have the foam sub filters in place. Also what kind of mileage are you getting with that set up?
#40
...needed my coffee
Yeah, I realized that a clogged filter = a lower mixture of air to fuel, not vice-versa, sometime after I logged off last night. Doh!
She's been running really cold all the time as well, and I've been thinking that I needed a thermostat but that could at least partiallly be caused by a rich mixture.
Didn't want to have to pull the tank, tho.
Well, if it's coming off for an air filter, I might as well buy a thermostat at the same time, huh?
"May you die from the bites of a thousand fleas," as the old curse goes. Even Hondas and Toyotas require some minimum amount of maintenance, I guess.
Thanks for giving me a chance to think out loud guys.
vtecv4
06-04-2008 10:08 PM
dive2277
10-26-2005 10:54 PM
