LED flasher unit problem
Hi guys,
I just installed front and back LED turn signals. They work great with the stock flasher relay except for the fast blink rate. I wanted to have a clean install and no resistors so I purchased the electronic LED friendly flasher from Clearalternative. After plugging in the LED flasher I get no response from the turn signals. The factory relay has three pins, LED two pins with an adapter for the factory plug. Any ideas, it is the weekend and Clearalternative is closed???
Thanks,
Pawel (Paul)
Thanks,
Pawel (Paul)
Thanks for the quick reply. I used your set up, but still nothing (I have yellow-live and black-ground lead on the relay). There is something loose in the relay box, I can hear it when I shake it. Will have to call Clearalternative on Monday.
Once again, thanks for your help.
Pawel.
Pawel.
Les
02-12-2006 01:23 PM
