Leaking Petcock
Old 01-19-2010 | 09:50 AM
mhaisten's Avatar
Wrench Bender
Leaking Petcock
My petcock diaphragm is leaking. The bike is running rich as a result. I went to my local Honda dealer and they said I had to buy the whole petcock. I then went to the local independent shop and they said they would order the diaphragm kit. 6 weeks later it is still backordered. Does anyone here know where I might get one?
I thought of eliminating the diaphragm, but I am not sure I want to count on the floats. Any thoughts?
Old 01-19-2010 | 10:00 AM
You're right in not counting on the floats. If a piece of dirt or varnish gets wedged in the inlet valve, you could end up with hydrostatic lock in one of the cylinders (fills up with gas).
How much is the whole petcock?
Old 01-19-2010 | 10:11 AM
mhaisten's Avatar
Wrench Bender
$150.00 for a new one. $38.00 for the kit.
Old 01-19-2010 | 10:51 AM
If I recall correctly the Goldwing 1500 kit can be used, but you have to keep the spring (or something like that) from your petcock and not use the one in the kit.
The main thing is that the diaphragm is the same from the Goldwing kit and that is what you need.
edit: "Also, I should mention that I bought a petcock repair kit from carbkitcapital for a GL1500 aspencade (91-95). The large diaphragm (the one that tears) fit fine, however the smaller plug element would not seal... it looked identical but the lip was not thick enough, and gas was leaking out of the vent. So... look out for that."
https://www.superhawkforum.com/forum...ad.php?t=20536
But he still had issues with getting it to seal.
Old 01-19-2010 | 12:47 PM
mhaisten's Avatar
Wrench Bender
I found a place on E-bay that had stock on them for $21 plus $5 shipping. Should be here in a few days.
If anyone else needs this kit the guy has at least 7 left.
Old 01-19-2010 | 12:52 PM
VTS's Avatar
VTS
OCMD honorary member
Seven of what left, Superhawk or GL1500 kits?
Thanks.
Old 01-19-2010 | 12:58 PM
mboe794's Avatar
A link would be appreciated. I'd love to snag one of them up.
Old 01-19-2010 | 01:15 PM
FL02SupaHawk996's Avatar
Fastest Color
This might be it:
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
Old 01-19-2010 | 01:26 PM
mhaisten's Avatar
Wrench Bender
Yes that is the link. I checked the part number and it is the one for the VTR1000.
Sorry for the lack of info, I was just so excited!
Old 01-19-2010 | 02:22 PM
Spaz''s Avatar
Spaz' is on a distinguished road
$15
Honda of St. John's over here in Portland OR got me an aftermarket rebuild kit for like $15-16 or something over the summer. I'll try to look around for the packaging in the garage when I get home in a bit - I'm just about to go out for a small flight in a minute or two.
-Matt
Old 01-19-2010 | 06:24 PM
mboe794's Avatar
Thanks for the link guys. Soon I shall have a diaphragm in my petcock. I've been going without one for a while.
Old 01-20-2010 | 05:43 PM
jason54's Avatar
jason54 is on a distinguished road
thanks for the link and info guy I have been running my hawk for 2 years without one
have had no problems however it is better to have so you can take the tank off without a big hassle saw the link and orderd one without delay.
you guy are the well you know
Old 01-20-2010 | 09:09 PM
OE Rebld
I believe this OE petcock PN includes the parts necessary, no?
http://www.ronayers.com/BrowseParts....=16953-ML0-034
vtrktm
09-23-2007 07:26 AM
xecutech
04-09-2007 09:53 PM
seattlesucks
06-18-2006 04:40 PM
sprhawk neil
03-01-2006 05:01 PM
Les
02-04-2006 11:28 AM
