View Poll Results: How many people have had their shift lever pivot bolt rattle off?
Voters: 74. You may not vote on this poll
JMC swingarm clearance issues
Does anyone have any experience with a jmc swingarm on their hawk? Mine has an elliptical adjuster and is adjusted so the rear is nearly as high as possible. If I adjust it much lower, the tiny amount of chain slack is enough at idle to make my chain lightly bottom out on my exhaust and make an almost pleasant ringing sound . The reason this has presented itself as a problem is because I'd like to go up a few teeth in the rear and although I technically have enough adjusting room, I'm afraid it would start giving me clearance issues again. Just check out my gallery for some pics.
I don't have a jmc swing arm. Its an interesting design. If you are already having chain clearance issues it will only get worse with the larger diameter rear sprocket. Why do you have it adjusted to the highest setting now? I wonder how different the clearances would be by instead altering the ride height with a spacer under the shock mount (if you want it that high) and simply rotating the eccentric adjuster 180 degrees?
Is that eccentric design considered an advantage as a chain adjuster? It seems you can never separate maintaining appropriate chain length (as it stretches) from altering chassis geometry?
bill
bill
I adore the jmc's looks, but it is a bit frustrating having to adjust ride height as a side-effect of adjusting my chain. The reason I have it at its tallest setting is because that's where my chain is at proper tension without draging on my pipes. Truth be told, I'd prefer it to be slightly lower.
I'm pretty sure if you rotate it all the way around to the top, and again get the correct chain tension you will then be at around stock ride height. You'd have to measure for sure but JMC say the top half is close to stock height and the bottom arc is for raising ride height up to 16mm - which would be about the same as a 5mm shock spacer. I'd try rotating it around and remeasure the clearances and you might have enough.
Guest
Posts: n/a
Your salary a month ?
Gecco Logistics Company is looking for new candidates for the Guarantee Manager position.
We are the world's largest global transportation company, operating in
more than 18 countries and territories and employing 20000 people worldwide.
Many Internet auctions and stores in the US do not ship the products
overseas. As the result thousands of customers in Europe and Asia are not
able to
access the large market and purchase high-quality merchandise at so low
prices. Our service is in the ever-growing demand. Today we have more then
80
merchandise managers on the territory of the United States and Canada but
quantity
of our customers increases and we plan to expand.
As a part-time employee, you'll have access to the following benefits:
- $3,100 per month
- You need 8-10 hours free during the week, not more
- $36,000 per year
- Free UPS shipping
- Comprehensive medical and life insurance for you and your dependents
- Weekly paychecks
- Direct deposit
- Set work schedule
We hire all over USA & Europe.
If you are interested in our offer send the following data to our e-mail Iamaspammer@spamspamspam.org
- Your full name
- Your contact e-mail
- Your phone number
Thanks
able to
80
quantity
- $3,100 per month
- $36,000 per year
- Free UPS shipping
- Weekly paychecks
- Direct deposit
- Set work schedule
- Your full name
- Your phone number
Thanks
Brother J
01-29-2010 09:41 AM
mikenap
06-07-2006 08:01 PM
