Indicator/ running light help
I wondered if anyone had found any LED running/signal for the font of the SH. I used these on my last SH http://www.chaparral-racing.com/Chap...18DDDE01B2C88D
But this time I wanted to try the LED route. I need flush mount that measures about 3" long and 2-2.5" tall. Same oval shape would be great. Any ideas?
also question about wiring. The right side (sitting on it) has (1) Light Blue, (1) Light Blue with Stripe and (1) Green wire. What is what? I did not pay close enough attention when I disconnected. Thanks.
Originally Posted by marmaladeboy
I don't remember the Light Blue and Light Blue w/ Stripe exactly, but the Green should be ground.
Assuming the LP signals currently on the bike share the same wiring as the new ones this should have worked. I think it's red/black/blk with stripe.
Well, you have three possible choices, with three different wires. There's only six total combinations.
IIRC, someone else had this problem with their aftermarket blinker lights from LP. The problem was the resistance...? I think...
Could be that it's a different bulb with different resistance. They are both LP signals though. One is only slightly less ugly than the other.
Really leaning more towards some LED markers and signals but i have been unable to find the size/shape that would work for the front. I think I can mod the Hyperlites to fit the tail.
I was referring to these Watson ones:
http://www.watsendesign.com/Honda_Pr...a_products.htm
from this thread:
https://www.superhawkforum.com/forum...t=turn+signals
from this thread:
from this thread:
from this thread:
