Ignition Not Advancing...???
Old 05-18-2008 | 10:26 PM
  #31
Yeah, 48s at your elevation is way too rich. 42s are too lean. I think 45s are right and then you can tweak it with the mixture screws. Is it still hanging up?
Old 05-18-2008 | 10:33 PM
  #32
ohh yeah, but I've noticed that my buddies '02 does the same thing... without the lowend stumble a crappy cold starting. Perhaps the idle hang is somthing that comes with the so called "updated" ECU & ICM.....?
Old 05-19-2008 | 02:58 AM
  #33
ripvanwinkle's Avatar
aka sirch345. vtr1000.org
ripvanwinkle is on a distinguished road
Cam timing was checked back in November of last year, then again in January of this year when I rebuilt the heads. I have enough faith in my mechanical abilities to to be completely satisfied with the results. As the assistant service manager at the local Honda/Kawasaki/Suzuki dealership, I work on bikes, quads and utility vehicles on a daily basis. I feel rather competent with almost all aspects of motorcycle diagnosis and repair... with the exceptional exception of major electrical diagnosis (gremlins ). For me to tear the valve covers off again to check the cam timing would just be like beating a dead horse. It is a very simple procedure that any motorcycle owner would benefit from knowing (i.e. valve clearance check and adjustment). I definitely appreciate all suggestions, just thought I'd give some background info.
Fair comment, after all you know your mechanical knowledge better than anyone!
Chris.
Old 05-19-2008 | 09:44 AM
  #34
RCVTR's Avatar
I'll say it again. The mixture changes when the air cutoff valve opens, changing the idle speed. Your friends bike does the same thing. The off idle stumble is a different problem. Solve them one at a time.
Old 05-19-2008 | 11:27 AM
  #35
But I also swapped carb with my buddies '98 and had the same issue, his runs as smooth as glass. I keep overlooking the fact they all the problems might not be related... just seems odd to me that a low mileage VTR would have multiple issues. Must have been built on a Friday...
lynchie
04-23-2011 02:42 PM
Ogre8472
08-31-2007 02:06 PM
timdske
04-07-2007 11:11 AM
scottiemann
03-03-2007 08:48 AM
gboezio
12-04-2006 08:42 PM
