ignition breaking up...HELP!!!
Hey guys...i have this issue with my 2000 vtr. the bike seems to have developed a running issue and i have narrowed it down to be ignition related. if i can get the bike running descent long enough, i do the alternator/charging system test as described in the factory service manual and it is not charging. the test led me to the rectifier/regulator. i don't have an issue replacing this but if i do, i still don't think it will resolve my ignition breaking up issue that i have while running the bike. does anyone know if there are any "normal" issues with these machines that occur after some time? could it still be a stator or could the rectifier/regulator cure this condition as well as the charging issue i had.
i am at my wits end with this and would greatly appreciate any information or help in this matter.
Its a R/R / stator issue only when theres a short circuit dropping the voltage.
Otherwise the bike will run fine with these parts removed.
Disconnect your R/R plug and then test run the engine.
also unplug the 3 wire stator plug to isolate that component as well.
thanks circuit burner...i appreciate the response and info. do you think the R/R could be the only cause of this problem or do you think that i might still have a stator issue? would you have any links or information on who to call to get either one of those parts? i can go to honda but i am also looking to save some $$$. hell, 9 year old bike with 15, 000 miles on it and this is the first real issue i had with it.
i'll do what you mentioned tonight and let you know the results of it.
cool. I will check back tonite.
Test stator with this test-plan www.motovoltage.com/tech.htm
Stators are pretty tough, and not very sensitive, but always start there in your troubleshooting procedure.
Circuit Burner knows the web site im speaking of. he really needs to add it to his signature line.
seb421
03-18-2009 05:54 AM
TexasWino
04-14-2008 01:54 PM
scottiemann
03-03-2007 08:48 AM
