If you know what the item next to the back pipe of the ingen
Please help. I was takeing off my pipes to paint them. I took off the back pipe, but to make it easier I took that 2.5inch thing off thats next to it(right side) so I could get a better opening to the pipe. But what the hell is it ? It doesnt go back in. Its the long metal thing you see on right side if your looking at the spring/pipe to ingen. Help...??
cam chain tensioner you need to make a locking tool to install it easily .You make it out of 1mm plate there is a pic the the workshop manual if you dont have a copy there is a PDF download link to it on www.ozfirestorm.com (probably one here )
Re: If you know what the item next to the back pipe of the i
I checked on http://ozfirestorm.com but coudnt find anything. Please help im scared I can feel inside and it seems like the peice I took out has an arm that holds something in place ? in takeing it out did stuff move that wont go back into place without takein apart the ingen ?
I posted a request over at www.ozfirestorm.com for some pic's give it a little time one of the fella's will post up the info needed from there PDF copy .Its in tech stuff just chuck in a post to let them know you are checking in for help
ok check www.ozfirestorm.com in tech stuff in the help for an O/S stormer thread there is a link there
Jeez, okay I found out whats up... People kept saying. "take the back screw out, so they spring wont be comprest, makeing arm extend" The screw has about two inches down a flat head acssesable head that when turned pulls the arm in!!! problem solved. thank you all....
motojoe
09-08-2016 04:05 AM
7moore7
06-14-2011 03:47 AM
