idle drop procedure
idle drop procedure
I cleaned the carbs and ready to synch, does anybody have a write up on how to do an idle drop procedure? I can't remember its been too long. also, should i check TPS or do they rare jump out of spec.
By idle drop do you mean fuel screw adjustment?
AFAIK, the tps has been discussed but it has been inconclusive as to whether it causes any significant changes. Of the write ups I read even out of spec tps don't seem to make a big diff even when corrected. YMMV
I like running a little richer than that....so does the bike. Try 2.0 - 2.25 turns out depending on your mods and elevation. Not to mention the adjuster tool is impossible to find and outrageously expensive at about $125.
They set it to fit whatever regulation they need to pass and then lock it down. If you notice, you're not supposed to tamper with it (you have to drill out the anchors).
I didn't read the OP very closely. I thought he was asking if he should regularly check TPS!
I got this tool for the job which really saves alot of work and money
Amazon.com: BikeMaster Extra Reach Adjustment Screwdriver 18-JVE4306: Automotive
27 clams & it works
27 clams & it works
thedeatons
06-21-2015 10:11 PM
DaxMiddler
04-28-2006 04:22 AM
