HELP!! Putting crankshaft sensor sprocket back
Old 07-14-2009 | 05:26 AM
blue firestorm's Avatar
blue firestorm is on a distinguished road
Need help putting the 3 small springs back in behind the sprocket, has anyone done this before? Its pictured in the service manual section 9.0.
Is there a special tool required??
Old 07-16-2009 | 05:22 PM
anyone done this job before??????
Old 07-16-2009 | 06:44 PM
RCVTR's Avatar
Are you talking about the backlash springs on the crankshaft primary drive gear?
If so, when you put the springs in, the primary drive gear and the thinner anti-backlash gear teeth are misaligned. You will need to rotate the thin gear until the teeth align. There is an alignment hole (maybe 2, for balance) that will line up when the teeth are aligned. Insert a drill bit that just fits the holes, to keep the springs compressed and the gear teeth aligned. Then you can slide them on to the crankshaft and remove the drill bit.
Apocalypse
06-14-2015 10:47 AM
smokinjoe73
11-09-2010 10:39 AM
skoshere
01-23-2009 10:25 PM
comedo
02-23-2008 11:19 AM
divingindaytona
03-28-2005 12:37 AM
