HELP!!! Ignition Switch won't Turn and It's SUNNY Outside
Old 04-13-2008 | 04:16 PM
TexasWino's Avatar
TexasWino is on a distinguished road
I used the key to remove the seat on my SH in order to replace it with a Sergent I obtained on this forum. I replaced the key in the Ign. and now it won't turn. I can push down and feel the spring but cannot get it to turn. The forks are not locked. Any ideas?
Old 04-13-2008 | 05:07 PM
synaptik's Avatar
synaptik is on a distinguished road
this is going to sound dumb but try turning the key 180 degrees and put back in ... 1 of my keys is like that on my hawk
Old 04-13-2008 | 07:08 PM
TexasWino's Avatar
I removed upper tripple tree then the ign. switch. Opened up the switch, removed the tumbler and cleaned then lubed it. Apparently it was gummed up and the pins oin the tumbler were not moving well. Refitted and all is good.
Old 04-13-2008 | 07:21 PM
Thumper's Avatar
Little late now, but i usually squirt WD40 into all my car and bike locks a couple times a year.
Old 04-13-2008 | 08:52 PM
This wonderful thing happened to me & I had to take a cab home to get my van I carry my vtr home. You should buy a set of security torx drives (15 clams) and remove the top triple, remove the 3 torx screws & you can start the bike with a stubby screwdriver until your new lockset comes that you bought on ebay ( I got the 3 lock set for 99bucks). Any deviation from this plan will result in great unhappiness as even if you fix the tumblers now with wd40, I promise they are dying and you will be stranded far from anywhere on your first date with mrs right with a rainstorm fast approaching( really ) I am not wrong about this...SmokinJoe
Old 04-13-2008 | 08:58 PM
Oh yeah, the security torx has a post in the middle to prevent a neophite with a reg torx from robbing you. Zip tie the small ignition switch in the fairing where only you know where it is & carry the stubby flathead screwdriver with you- some of us here in NYC leave it that way all summer since it absolutely confounds would-be hot wire guys with hammers & screwdrivers.
Old 04-13-2008 | 09:06 PM
Gregw's Avatar
Harbor freight sell the security bit sets. I think hollow tip Torx is what you're looking for. $7.99 http://www.harborfreight.com/cpi/cta...emnumber=91310
Old 04-14-2008 | 12:04 PM
TexasWino's Avatar
Sounds like Smokinjoe had a bad experience.
Thanks for the advice. I'll start gathering parts.
Old 04-14-2008 | 12:54 PM
RickB's Avatar
LOL - I can picture the look on the would be thief's face....
Hawkster
04-20-2015 06:18 AM
rz_racer_69
01-14-2012 09:43 PM
inderocker
04-26-2010 06:44 PM
fundgh
01-06-2010 03:26 PM
Hawkrider
03-05-2008 05:33 PM
Quick Reply: HELP!!! Ignition Switch won't Turn and It's SUNNY Outside
