help clutch problem
Old 12-02-2011 | 04:40 PM
justin a.'s Avatar
justin a. is on a distinguished road
help clutch problem
ok well i just bought a 99 superhawk monday and took it out a few times. today i went out to start it to take it for a ride and no clutch. i'm probable take a took at it tomorrow anyone know there i should start or have and thoughts on my problem.
Old 12-02-2011 | 04:44 PM
bass4dude's Avatar
bass4dude is on a distinguished road
I think your post requires a little bit more info before answers are given
Is there pressure on the lever? Does it stay engaged, or stay disengaged? Can you still shift the bike? And what are the conditions of the line like? Fluid? Any noises?.......
Old 12-02-2011 | 04:56 PM
justin a.'s Avatar
sorry. no weird noises i can't shift the bike its like im not even using the clutch when i try to put in gear. i haven't noticed a leak so i don't think i blew the line. i didn't even know it didn't work until i went to put it in first and it stalled out. I'm at a loss i don't know why it worked when i put it in my garage and now its busted.
Old 12-02-2011 | 05:25 PM
The issue is in the slave cylinder but there are others here that can help you or explain the hows and whys.
Old 12-02-2011 | 05:31 PM
justin a.'s Avatar
i don't know the clutch seems to be working i can change gears when the bikes not running.
Old 12-02-2011 | 05:37 PM
Wicky's Avatar
As per 8541Hawk check the clutch slave seal and cylinder condition. Grit can get ingested which scratches the slave cylinder and/or damages the seal and fluid can slowly seep without necessarily causing a full blown apparent leak.
http://www.ronayers.com/Fiche/TypeID...VER_WATER_PUMP
Have a search on this forum for bleeding clutch for hints and tips on this job as the smaller reservoir dictates more attention than say bleeding brakes.
Old 12-02-2011 | 06:34 PM
matt365's Avatar
you can change gears because you're using the gear shifter, not the clutch. You can go through the gears on any bike without the clutch when the bike is off.
You've got air in the hydraulic clutch, as others have stated because of a leak in the slave cylinder.
follow the clutch line down to the engine and check if there is any fluid on the cover.
If you don't already have a service manual, do a search and download the *.pdf
Old 12-02-2011 | 07:44 PM
justin a.'s Avatar
thanks guy i'll take a look tomorrow
Old 12-02-2011 | 11:31 PM
saige's Avatar
the boss
definitely,follow the line from top to bottom and make sure there is no pin hole leak.
once you do that,make sure there is no leak where the cup is or where the lever meets the plunger in the MC.the MC should have pressure,make sure it does.
on the bottom of the sprocket cover,there is a little hole.if there is some sort of a leak,it will be wet under there,have paint peeling or look rusted in a way.
but most of all,I noticed you said " i didn't even know it didn't work until i went to put it in first and it stalled out."if all else checks out.make sure the kick stand is up before putting in gear.it will turn off if not.if the kick stand is up and it stalls out,its possible it could be the kick stand switch.
but no matter what,check everything else first.
imho,make sure you clean and flush all lines,this will make a big difference.
good luck.
JasChen
05-08-2018 07:50 PM
bostonhawk
09-01-2012 09:45 AM
mill7163
05-07-2008 05:01 AM
winder
04-12-2006 03:51 PM
