hard rain=poor performance, studder, stall
so basically when it rains, the bike hates it. anyone else have this problem? i thought it was because i modded the airbox, but i bought a new one. im thinking wet coils, battery, etc. ideas?
There is a tank vent tube that leads down to the ground on the front left side of the bike. It can pick up water while riding in the rain which creates vapor lock in the tank. Tank vapor lock will not let gas flow from the petcock properly, thus the poor running.
Another cause is water getting past the front spark plug cover and creating a misfire.
On the sidestand switch...
Remove the bolt retaining the switch that is on the side stand itself, clean and pack the backside of the switch (there is a "tang" in a recessed cavity that engages the sidestand), and pack the cavity with waterproof (not dielectric) grease; reassemble.
I sealed all the connectors including the ignition switch with some electrical grade RTV 4 yrs ago after the same happened to me in the rain. Haven't had that problem since. By the way, dielectric grease only prvents corrosion.
