gipro type-x problems...?
If there is some one who has installed gipro gear indicator could you please help me out?? I have connected the device in yellow/green wire which comes directly from the ecu box, "L" flashes slowly all the time but it doesn´t give me the "1" to start operating. I think that it is correctly connected but whats wrong then? I checked the color in cord several times and so on...
When i but 1 gear in it starts to roll the but i don´t think that its going to get the RPM reading anywhere? So it senses speed but not tacho? Whats the color in RPM wire??
i thought those things took guessed at your gear based on rpm vs speed or something funky like that, so youd have to ride around and let it learn. what did the instructions say about first time use of them?
My bike is on rear stand so i can but any gear on etc.
So the gipro doesn´t get the rpm signal at all, the instructions sayd that the rpm signal color is yellow/green and thats what the haynes manual says also? So whats fucked up or is the gipro fucked up?
I let the bike idle for about 5min or so, it should have found the rpm by then... instructions say that let the bike idle for a little while and the "L" should flash quikly and turn into "1", then but first gear in... I´m reading the instructions now and i get the feeling that in idle it should found the rpm signal in "seconds". I let it idle for 5min and nothing?
where did you get the tach signal from? i remember trying to hook up a tach in my old car and thought i could take it right from the cluster, but the cluster would infact take a signal and convert it into rpms so it wouldnt work there. i havent dug too deep into these bikes but is there a tach signal located on the coil? maybe try that if you havent already. sounds like its either not getting a clean signal or the unit is defective
The bloody ****** won´t work even i had a 8pound hammer with me!! So its not the yellow and its not the yellow/green...waiting for healtech to give me another color to try...feeling like a test dummy.. my friend is coming to give it a try if a can´t get it working tomorrow perhaps...
That sucks man. I'm surprised no one on here has chimed in yet. I'm sure a couple guys have to be running these things. I'm not sure what else to say short of wrapping the wire a few times around a sparkplug wire like they do during the emissions testing. Lol
Tomorrow my friend comes to test the damn thing...he said already that the indicator is busted... He looked at the wiring diagram and said that the correct cord is yellow/green. Thats the wire i tried first with no luck.
By the way, i noticed something else during this damn wire hunt... My carbs rubber inlets were totally loose.... i wondered few weeks ago why my bikes idle waves so much...don´t wonder anymore... it seems that the bike vibrates so much that all the nuts and bolts loosen every now and then??? I´m gonna by 1L Loctite tomorrow and glue the damn thing together Both of the rubber throats where totally loose...
lol man mines got a shortened and modded set of jardine high mounts. you wanna talk about vibrating mine does it. if i had a passanger seat id sell orgasms to women for christs sake. its loud and its angry and i love it. im waiting for the forks to fall off one of these days, lol
Problem solved!! The color of the wire was indeed correct in the gipro manual!! Solid yellow with green stripe! The problem in my case was this: I routed the wire too close to other electrick wires and they interfered the rpm signal wire and the result was that the indicator wasn´t working at all!!
Also make sure that the connection to the yellow/green wire is solid before packing everything up!!
Got it working today in few minutes with my friend helping me.
New would have costed 113$ or 83+shipping!! Damn thats expensive!
Well the bike was in rear stand when i tested it at first time and it took quite easy my downgearing. It has a second delay and then it pops the new gear number...quite fast in my opinion. Well lets see it in action next weekend...
So it run today about 100mails with my hawk and tested the gipro type-x and it worked like charm!!! It has about 1second delay after you put another gear on and release the clutch. No wrong gear indications etc. Only thing i noticed was that under 2000rpm it starts to flash so theres too little rpm to detect what gear is on. But anyway i love it!! Easy to install and works very well!!
I try to remember to take pictures the next time i go to carage. My bike is located about 30km where i live currently because i don´t have place to but it to away from snow etc. Its summer in here but it rained snow today when i went for a ride temp is +5 celsius
problem with the gipro x-type g2
hello there, oi am also having problems with setting up the different gears, it if gets into the state where it moves to 1 and where you have to rev up untill the 1 starts blinking fast but that doesnt happen.
any ideas?
any ideas?
Randman
03-30-2007 06:38 AM
Speed_Demon
02-02-2006 06:52 PM
mrjakeanderson
06-02-2005 09:39 PM
