Gastank removal without spill?
Old 07-13-2009 | 09:30 AM
chickenstrip's Avatar
chickenstrip
Okay, I feel really stupid for asking this, but what is the procedure for tank removal without a gas spill? Sometimes I get it off without a hitch, and other times, like this weekend, I get gas everywhere. Does it matter what order the lines come off?
Old 07-13-2009 | 09:45 AM
Close the petcock valve and plug the lines leading to the carbs (lift them upwards as soon as they come off to prevent them emptying themselves) and you shouldn't have any spillage.
Old 07-13-2009 | 09:49 AM
chickenstrip
Petcock valve? There is no valve, it's just the vacuum tube, right? I thought that I by getting that off first I would prevent spillage, but no ... I'm getting gas out of the tank.
Old 07-13-2009 | 09:55 AM
at the very back of the tank (close to the bolt that secures it to the frame), there is a semi-circular steel wheel with a square protrusion, this is the petcock valve. You turn it to the extreme opposite end (forget if it`s CW or CCW) and this will shut the valve.
I think your problem has just been found.....
Old 07-13-2009 | 10:11 AM
Thumper's Avatar
yep
8mm wrench i beleive and don't forget to turn it back on after reattaching the fuel lines
Old 07-13-2009 | 10:17 AM
chickenstrip
Great! Thanks guys.
Old 07-13-2009 | 10:26 AM
trinc's Avatar
after shutting off the valve fire up the bike & run it 'til it dies... that will clear the fuel in the lines ( and bowls ).
note: if your petcock is in good condition, manually turning the valve off is NOT required. pull the petcock vacuum line & run the bike 'til it dies.
tim
doomcookie
07-23-2009 02:19 PM
duran
04-24-2008 07:29 PM
Doc
08-25-2007 05:39 PM
vtrlvr
02-08-2007 08:55 PM
dpenix76
11-02-2006 05:03 AM
