Fuel gauge again.
Fuel gauge again.
So in my long endeavor to get my 07 cbr600rr dash to read a 2nd gen fuel sensor, I am calculating whether I need to source a fuel sender from that bike (cbr)or can I adapt the vtr (gives 4-10ohms full / 81-91ohm empty) to the cbr dash which wants 12-14 full and 119-121ohms empty.
I have yet to get a resistor to make much difference. A 10 ohm reststr doesnt change the display but a 47ohm one does somewhat.
Someone has to have done something really similar right? Or am I Christopher Columbus?
Well, changing the value of a non linear resistor pot with an added resistor is danged tricky, and 9 times out of 10 it doesn't work very well... So you're probably not the first to try... But most will just get the CBR sender unit instead...
