Front carb flooding after hard braking
Old 08-15-2013 | 11:05 PM
Spoot's Avatar
über-n00b
Spoot is on a distinguished road
I read in here somewhere, that after closing the throttle and hard braking - it causes unspent fuel to jump from the rear carb into the the front carb and flood it out....then a loss of power until the extra fuel gets used.
I can't find the post, but it sounded like..."yep, it's a design flaw..."
Recently, I've had a number of confidence inspired late-braking opportunities (after the long straight) on the track, only to be followed by a massive loss of power when rolling on the throttle at the next apex...probably ticking off anyone following me. This happened numerous times throughout the day.
Has anyone found a work-around or a solution to this??
One friend suggested putting something in between the stacks to prevent this, but where would that fuel go?
Another friend suggested 'Just don't brake so hard and carry more speed through the turn!'
Help.
Old 08-16-2013 | 12:55 AM
Wicky's Avatar
www.vtr1000.org • View topic - Brief bad fuelling after heavy braking from high speed
Old 08-16-2013 | 11:30 AM
RCVTR's Avatar
Like the thread that Wicky pointed to implies, the float vent tubes can be the cause. I routed my vent tubes together, pointing down between the carbs, instead of out the sides of the carb frames. The problem went away.
Old 08-16-2013 | 04:54 PM
NightHawk1911's Avatar
NightHawk1911 is on a distinguished road
Same Here. I trimmed them shorter and routed them inside the carb assembly. Havent had any issues with it flooding since.
Old 08-21-2013 | 09:54 PM
Spoot's Avatar
über-n00b
Thanks guys!
My next mod....
Big_Jim59
06-05-2015 04:31 PM
mlaw
06-08-2012 11:54 AM
turbotim
06-25-2011 09:29 PM
gpzturbo
10-14-2010 04:04 PM
kshuck2
07-14-2008 04:21 AM
