Filter, sub A/CLNR --- HELP
position #10
http://www.ronayers.com/fiche/200_03...0&parent=13160
i'm going back to stock ( removing the K&N filter & pipes ) the K&N filter came with block off caps for these sub filters. what are these for ?
should i leave these cap'd ? i do have a sheet of air condition filter i could cut to size. ( dealer didn't have them ). just curious as to what this extra air flow is for ????
thx
tim
thx
tim
They supply filtered air to the back side of the carb. diaphrams which allows them to close. The stock air filter has those K&N caps built into it. If you have been running without the filters you might want to pull the carbs and clean out the crap that is built up in the slides.
tim
roisman
04-01-2007 03:08 PM
