/facepalm 2 day old headlight blew
I am a bit nervous about this. My high-beam blew the other day so when I sealed up my exhaust(which has made a world of difference). I put in a silverstar ultra headlight. I was happy for it and then today (less than 2 days later) under hard acceleration in 4th it brightened and then blew again. I am hoping this is a known issue with the bulb (55/60w), but am afraid that the truth has to do with another failing R/R. Any Ideas on how I can test this tomorrow?
check the voltage specs on the bulb itself. i went threw 2 bulbs in my srad that were too high. they also ended up frying the light plugs. check the voltage at the battery on a warm bike at idle, then at 5k. voltage shouldnt be above 14.5 -/+. any higher and that may be causing the blow out.
If I do need another R/R this model would be a drop in right?
93 94 Honda CBR 900RR Voltage Regulator Rectifier
seems like honda used it all over the place and it has fins compared to my matchbox RR
i wouldnt go old school. the whole point of replacing your RR with another RR is to get the modern technology and manufacturing tolerances of newer RRs. i would say that RR would be as bad or worse then your factory one.
You do know that I wrote a "manual" complete with a list of what R/R's are a good replacement, just a week or two ago, right?
https://www.superhawkforum.com/forum...why-how-25117/
I contacted Jim at eastern Beaver about what parts I should order and he said google it lol.
In any case this is what I ordered for an FH011 "big fin" R1 R/R. Maybe someone else can use this info.
Description Unit price Qty Amount
3P250WP-QLW-Female Connector Set
Item# 3P090WP-QLW-Set $18.62 USD 1 $18.62 USD
5P250-305K Male Housing Only
Item# 5P250-305K-M $3.29 USD 1 $3.29 USD
CNA-M250-TL-2 Terminal
Item# CNA-M250-TL-2 $0.24 USD 3 $0.72 USD
CNA-M312-TL-2 Terminal
Item# CNA-M312-TL-2 $0.33 USD 2 $0.66 USD
Subtotal $23.29 USD
Shipping and handling $5.82 USD
Total $29.11 USD
Payment $29.11 USD
Subtotal $23.29 USD
Total $29.11 USD
Payment $29.11 USD
EngineNoO9
09-02-2006 10:15 PM
igeorgei
09-21-2005 01:22 AM
