electronics geniuses - home-made speedo corrector?
Hello,
I'm fiddling with the idea of changing my gearing, but I don't want to cough up $115 for the speedo healer. Too many features, a whole computer in there - it just seems like overkill when all we need is to generate an output pulse whose frequency is determined by a variable input pulse.
This sounds to me like the kind of thing that someone with the right know-how could wire up with some diddly little $5 chip and the right combination of resistors capacitors and diodes - and then we could all use it.
Has anyone looked into this?
-Avram
-Avram
there are a number of ways to go about it but a PIC would be the easiest. and yes it's very cheap... and not that hard to program BUT - you'll need to make a PC board & seal it in a box, make a harness with the proper connectors to be plug & play....
buying just a couple parts at a time w/ shipping i'd bet you'll spend $50.
then you need a programmer ( yes, i have a few ). you can get a compiler
free after you debug the program.
by the time your done with it you might as well just spend the $100 to buy one ( unless you have a lot of free time ).
old school... you could program ( by the external DIP switches ) a simple counter but it'll have a lag in it. there are ways to reduce that but would require more space.... so like i stated a PIC would be the way to go.
imo
tim
imo
tim
Here is a kit to do it yourself:
http://www.jaycar.com/productView.as...=&SUBCATID=347
Here is programming that one: http://www.600rr.net/vb/showthread.php?p=1526467
To actually design one yourself that could be programmed for different sprockets etc would be a pain..
Really even with that "cheap" one up there, with the hassle and time etc, just buy a speedohealer or yellowbox for $115 and be done with it. Cheaper in the long run.
FWIW, I do like to keep track of my fuel economy. I mean yeah, the hawk is a guzzler by bike standards, but I still like to know if its guzzling more than it should be.
Also, if you're passing them, that could mean a lot of different things. For example, if they are going 65, it doesn't mean much. If they are going 85, then you could get into a fair bit of trouble.
corrector, electronics, healer, home, homemade, jaycar, kit, made, make, pc, programmer, programming, speedo, speedometer, superhawk
