Draining Coolant
Old 07-14-2007 | 02:22 PM
bowhawk's Avatar
Draining Coolant
I have to drain the coolant and replace it with water for some upcoming track days. Just thought I'd ask if anyone has any tips or bad experience with running just water. I was going run water until the end of the summer. Thoughts?
Old 07-14-2007 | 04:33 PM
marmaladedad's Avatar
Hmm?
I would recommend running water + Water Wetter. It has better cooling properties than straight-water.
You'll definitely want to switch to antifreeze coolant for the cold temps.
Old 07-14-2007 | 07:17 PM
SD996's Avatar
SD996 is on a distinguished road
If you run only water in a dirt bike it will seize the engine. I think the same thing would be true for a street bike. I'm no expert, but I beleive antifreeze also acts as anti-boil. They make special coolant specific for track use.
Old 07-14-2007 | 08:08 PM
azhawk1's Avatar
azhawk1 is on a distinguished road
I would run engine ice personally
Old 07-14-2007 | 08:14 PM
kevink2's Avatar
kevink2 is on a distinguished road
I think with straight water you are also risking corrosion.
Old 07-14-2007 | 09:05 PM
Hmm?
Some trackday providers/organizers specify against EI because it has a glycol (I think...?) based additive that makes it as slippery as antifreeze.
Old 07-15-2007 | 12:12 AM
Chitownson's Avatar
Chitownson is on a distinguished road
Straight water
I'm no expert but I believe you have to have some kind of lubricant/additive for water pump.
CruxGNZ
04-29-2013 04:56 PM
Unzie57
10-22-2012 07:30 PM
Super-Rob
07-30-2010 11:08 AM
05xman
09-22-2007 07:40 PM
faz
07-29-2004 11:58 AM
