DIY Chain replacement....?
Old 05-10-2010 | 06:05 AM
  #31
nath981's Avatar
Originally Posted by herman_g60
At 15K miles, I replaced both sprockets and the chain without cutting the old chain off.
I bought the chain + sprocket kit from Dennis Kirk and had the new chain pressed at a local shop.
You can get the old chain off if you can take your back wheel off and the one small front peg allen bolt. You'll be able to jimmy the chain through and off if you can do both of those. You'll have to rotate the foot peg around with a mallet maybe.
PLEASE TELL ME IF THIS IS FROWNED UPON DOING IT THAT WAY! I just didn't want to buy more flippin' tools for a one time job.
that's interesting, I didn't know it could be done that way. That said, cuttin the chain is the easiest part if you have a dremel or other cutting wheel which for me are tools that have proved invaluable ove rthe years for all manner of tasks.
Old 01-29-2011 | 12:28 PM
  #32
justinity's Avatar
Über Member
You did it like this?
Old 01-29-2011 | 01:36 PM
  #33
nath981's Avatar
yeah, you can. If I would have known, I may have opted for it. However, I bought the rivet tool because I wanted to shorten the wheel base by shortening the chain as much as possible; and thought the master link thing might not be good cos it was recommended against by the chain manufacturer.
The master link evidently does work fine for the SH and so does the pre-connected chain install, so you have options.
Old 01-29-2011 | 01:40 PM
  #34
Wicky's Avatar
It's the easiest way - as long as you loosen nuts off before putting it on a stand and getting the rear wheel out. Plus you can rivet the chain off the bike and slip the new chain on - Just remember to torque the swing arm nut back up correctly.
Old 01-29-2011 | 01:42 PM
  #35
justinity's Avatar
Über Member
Swing arm nut?
Why would I have to loosen that?
Old 01-29-2011 | 02:13 PM
  #36
Swing arm nut?
Because it holds the left foot peg assy. on.
Old 01-29-2011 | 04:17 PM
  #37
Just_Nick's Avatar
Who are you?
Correction:
Easiest way to get the old chain off is to just cut it off with a dremel or sawzall.
Old 01-29-2011 | 05:01 PM
  #38
Originally Posted by Just_Nick
Correction:
Actually a set of bolt cutters is the "easiest" way but I use a die grinder
Old 01-30-2011 | 12:28 AM
  #39
wiredhawk's Avatar
wiredhawk is on a distinguished road
Hi Guys. I am doing the same thing right now. I went for standard gearing and a 530 chain. I understand the rear sprocket nuts are 80ft.lbs but want is the front sprocket bolt tension??? I remember reading on here about a year ago, tensioning the bolt after the chain is fitted then using a block of wood in the rear wheel to stop the sprocket from turning but I can't find the specs in the manual. Thankyou. Dean.
Old 01-30-2011 | 01:01 AM
  #40
justinity's Avatar
Über Member
I just installed my rear sprocket I tightened it to 81 foot pounds to be safe
Old 01-30-2011 | 06:37 AM
  #41
Stevebis1's Avatar
Originally Posted by residentg
I run a 530 DID XRing chain with a 43 (+2) in the rear, and stock up front (I forget the # teeth). I needed 104 links to get it to fit, the 102 was too short.
Whats up with this?
Was planning on picking up a kit from sprocket center with a 43 tooth rear and they indicate they cut the chain to size.
I currently run 43 with the OEM chain, but the chain was already somewhat stretched when I put the 43 on 2+ years ago.
This is the first post I've seen with anyone indicating a problem, but if there was ever to be a length problem a new chain is where it would show up.
I also imagine you might need a touch more slack if you put the chain on already riveted. Has anyone else had to go 104 with a 43 rear?
Old 01-30-2011 | 11:16 AM
  #42
Pg 1-11 in your service manual. 40 Ft lbs or 54 N-m
Old 01-30-2011 | 11:17 AM
  #43
Whats up with this?
The stock 102 link chain will work fine with a 43t rear sprocket.
Old 01-31-2011 | 09:47 AM
  #44
nath981's Avatar
Whats up with this?
Mime's 102 links for 15f 44r, but that's the shortest because the axle is as far forward as possible
Tweety
04-27-2011 01:04 AM
Thumper
04-21-2008 05:53 PM
reaper
09-22-2007 11:15 AM
duran
08-27-2007 08:57 AM
BLAKCK HAWK
06-14-2007 09:17 PM
