Dies Under Hard Braking
Old 05-31-2015 | 04:48 PM
Big_Jim59's Avatar
I know this has probably been covered before but I noticed that if I am coming to a stop, and slow down gradualy, all is fine. If I stand it on it nose the RPMs will drop and it will die. What have I missed?
Old 05-31-2015 | 04:55 PM
Wicky's Avatar
There's a carb overflow hose that runs through the carb brackets that's routed through a tight bend that can get kinked - take a peek underneath the airbox next time you're under there. Symptoms as you've described are for it to happen under ermergency heavy braking.
Old 05-31-2015 | 05:08 PM
NZSpokes's Avatar
Mine had this and I moved the breathers to face down. It would get a bit exciting on the track when it did it.
I believe there was a Honda service bulletin on it.
Old 05-31-2015 | 05:30 PM
Big_Jim59's Avatar
I know exactly what you are talking about. They are the only hoses I didn't mess with. They still have the original dust and grime on them. I'll take a look the next time I have the air box off.
I have started to compensate by pulling the clutch and rolling the throttle on a bit. For me, it's too much to remember when you have cars to worry about.
Old 06-01-2015 | 06:56 AM
AndyMX47's Avatar
Suffered from that issue - pulled the carb vent lines out of the carb braces, pointed them straight down, trimmed the ends at an angle - no more issue.
Old 06-01-2015 | 01:00 PM
Big_Jim59's Avatar
Thanks everyone. I guess I'll have to pull the air box one more time. It would be so bad but I filled the tank. Isn't that they way it always works?
Old 06-03-2015 | 09:14 AM
AndyMX47's Avatar
With patience you can re-route the vent lines with tank and airbox in place
Old 06-03-2015 | 10:00 AM
Spoot's Avatar
über-n00b
Spoot is on a distinguished road
I ran them straight, but I still have issues once in a while at the track.
4 or 5 times at Road America yesterday, iirc.
As stated...under heavy braking. Irritating.
Next time I'm in under there, maybe I'll try the 'pointed down' and angle cut hoses.
Old 06-03-2015 | 02:40 PM
NZSpokes's Avatar
Something I remembered that is very important. In fact it should be a sticky.
Cut the rear hose shorter if you do this. I had the hose get stuck under the throttle stop on the carbs and jammed the throttle wide open. I had this just before a turn.
Cut the hose so it cant reach the carb stop for the throttle.
Old 06-03-2015 | 09:57 PM
Spoot's Avatar
über-n00b
^oh my....another good thing to look for.
thnx!
Old 06-05-2015 | 10:58 AM
It is only the front carb which needs the line rerouted and there is no need to cut angles in the hoses.
If you want you can shoot me your e-mail and I can send you a copy of the bulletin
Old 06-05-2015 | 02:15 PM
Mike, is there anything wrong with simply removing the hoses? Or actually, just the front hose.
Old 06-05-2015 | 02:27 PM
CrankenFine's Avatar
I think this something that could be useful if posted in the knowledgebase.
Old 06-05-2015 | 04:31 PM
No, or at least I have run mine without the breather hoses for a bit over 10 yrs now with no problems.
Spoot
08-21-2013 09:54 PM
meanhawk98
02-13-2012 12:27 PM
natewill
06-19-2011 05:42 PM
gpzturbo
10-14-2010 04:04 PM
ClevelandSuperhawkRumble
04-29-2007 09:03 PM
