Coolant weep hole mess!
Old 09-24-2011 | 10:56 PM
msethhunter's Avatar
I am getting a lot of oil out of the weep hole. Oil level is right on par with where it should be, and I don't seem to have an excessive amount of oil in the sir box. PCV system also seems to be functioning as designed. Any thoughts?
P.S. I usually ride fairly hard, and see RPM's from 4500> rev limiter regularly.
Old 09-25-2011 | 01:17 AM
franz125's Avatar
franz125 is on a distinguished road
Put new lipseal to waterpump and check engine breather.
Old 09-25-2011 | 08:09 AM
comedo's Avatar
What year is your bike? The later ones, from at least 2001 on, had a drainage tube from the weep hole. Is the oil coming from a tube or directly from the weep hole? Usually it's coolant leaking from the weep hole that shows that the water pump seal needs replacing.
Old 09-25-2011 | 10:29 AM
It's not coolant, it's oil. I run water and WaterWetter. Mine is a '98. Sound like if they put a drainage tube on there, it was to fix the issue I am having then. It's not a whole ton of oil, just enough to notice and annoy me.
ricoshai
09-18-2014 06:21 PM
standzchop
06-11-2013 11:14 AM
mboe794
04-06-2011 05:40 AM
vtrktm
09-23-2007 07:26 AM
Texassuperhawk
05-13-2007 11:56 AM
