clutch wont pump up?
Old 03-18-2011 | 07:50 PM
shake-n-bake's Avatar
Umm...I'm awesome. Duh...
shake-n-bake is on a distinguished road
i fill the reservoir up, pump the handle, bleed the bleeder on the slave cylinder, no air comes out, just fluid and the clutch will not build pressure. time for a master cylinder rebuild?
Old 03-18-2011 | 09:54 PM
Little_Horse's Avatar
2nd mouse gets the cheese
Sometimes the air sits in the top banjo fitting on the master so squeeze the handle and slowly loosen and retighten banjo using the pressure to push out the air then close the banjo before the pressure equalizes. after the air shoots out be aware some fluid will come out too so towels. Then bleed the system again and you are good to go. Or you will need a mityvac bleeder to aid.
Old 03-19-2011 | 04:57 PM
Stumpy's Avatar
Best way is to get a vacuum pump put it in the bleeder after its lose and suck the fluid out until no air Tighten bleeder before you take the hose off I do this every year. Pump is cheap
Old 03-19-2011 | 06:01 PM
talking about the one you can rent from say advance auto?
Old 03-19-2011 | 08:32 PM
ninjagoalie's Avatar
I got a mity-vac at Harbor Freight Tool store for under $30 on sale. It was a great investment for brake and clutch bleeding. makes the job 100 times easier and does it better.
Old 03-20-2011 | 11:50 PM
Stumpy's Avatar
+1 get the one that has a case a little more but makes it a lot better to store I cheaped out and have been sorry ever since.
Mr.Lojo
02-07-2015 03:48 PM
BigJMerc
05-04-2011 01:14 PM
kenhawk
01-28-2010 10:52 PM
crash06
09-06-2008 04:15 PM
camaroguy72
09-07-2007 04:51 PM
