Clutch slipping problem, advice?
Old 08-02-2011 | 10:03 AM
firedog55's Avatar
firedog55 is on a distinguished road
First a little history, SHawk is a '99 with 9,600 miles. Adult owned and ridden, never abused. Oil/filter changes with non-synthetic oil every 3k miles.
I recently did some mods, Pazzo levers, Coerce counter shaft sprocket cover(CSSC), and changed oil to Mobil1 4T 10/40 synthetic. Prior to mods there were no issues with the clutch.
While the CSSC was off all parts were thoroughly cleaned. The clutch MC, line, and slave cylinder were flushed and bled using a MightyVac and DOT 4 fluid, no banjo lines were broken.
Now for the problem. When cold the clutch was grabby, after warm it slips.
If I ride easily, with small amounts of throttle it shifts fine and will go down the road normally. As soon as I open the throttle it slips badly.
Any suggestion? Is the synthetic oil too slippery? Has the Pazzo clutch lever, or Coerce CSSC changed clutch actuation? Do I need a new clutch after only 9.6k miles?
Thanks for your replies.
Old 08-02-2011 | 10:17 AM
Stevebis1's Avatar
Your clutch is very likely fine. The issue is probably with the with the clutch slave. The hydraulic clutch is known to be really tough to blead.
Old 08-02-2011 | 10:29 AM
Some members have reported different oils causing their clutch to slip, but you may want to bleed the lines again... 8541Hawk has had this cause his clutch to slip inexplicably.
Old 08-02-2011 | 10:33 AM
comedo's Avatar
Try it with the stock countershaft sprocket cover.
Old 08-02-2011 | 11:35 AM
Wicky's Avatar
Go back to your original oil or try semi-synthetic (recommended)
Old 08-02-2011 | 11:50 AM
speedkelly@aol.com's Avatar
Some oil can cause this issue. Fews years back on a Aprilia Mille, changed oil with for some very expensive AGIP sythetic superduperslippery ****. First ride out not able to do any wheelie! Changed the oil all good. Try the oil change thing first.
I run Mobil 4T 10w-40 with no problems. In fact the bike shifts better with it than any other oil I tried.
Try to re bleed the system before you do anything else.
Old 08-02-2011 | 12:27 PM
Since this is actual motorcycle oil, I would change that out last..
My vote is the hydraulic system in some fashion, that or the sprocket cover.
Old 08-02-2011 | 07:48 PM
firedog55's Avatar
Thanks Guys, good advise. I'll try to bleed the slave cylinder again first, then try the factory CSSC if the bleeding doesn't work. Finally go back to the non synthetic oil last. I really wanted to use the systhetic though. I'll post when I get it workin.
Thanks again for all the replies.
Old 08-02-2011 | 08:15 PM
Do you have the gasket under the slave cylinder? How about Pos # 3&4 on this diagram:Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
If you left any of those bits out, that could also cause your problems.
Old 08-06-2011 | 05:02 PM
firedog55's Avatar
I found the problem. When I put the Coerce CSSC on I failed to put the stamped steel gasket from the Honda CSSC on (color me dumbass). I didn't realize that it was a separate part as it was stuck to the magnesium cover. I got to looking at the distance the clutch actuation rod was moving and realized it wasn't allowing the clutch to completely engage. So I put the steel plate on under the Coerce part(next to the transmission case) and the clutch functions fine.
Thanks Again for the replies and help guys. That's why this forum is such a pleasure to be a member of.
As soon as my rear seat cowl comes back from the painter(he messed up my graphics) I'll put up some pics.
Chrisguilday
11-06-2018 06:57 AM
hangerbaby
07-22-2012 07:55 PM
Starbucks Fueled
03-14-2011 12:16 PM
kevinmeller
05-01-2009 06:20 AM
XLSR-VTR1
06-28-2007 08:08 AM
