Clutch engagement/disengagement problems
Old 11-25-2008 | 05:02 PM
ATLSHawk98's Avatar
ATLSHawk98
Unhappy Clutch engagement/disengagement problems
I have searched around the forum a good bit for my solution, but with all my reading, most people seem to have the exact opposite problem that I have. The engagement point of my clutch is suddenly now at the point where the handle is on the grip. To be more specific, it actually doesn't ever fully disengage any more. If the bike is running, and you pull in clutch, and pop it into 1st gear, it is still slipping enough that it will either kill the engine or make the bike crawl forward. It just won't fully disengage anymore and almost makes it undriveable.
Most of the other clutch issues that I have read about revolve around a late engagement with the handle nearly 100% let out. I am going to try to bleed the system with new fluid tomorrow. Any thoughts or help would be so greatly appreciated!!!
Old 11-25-2008 | 06:24 PM
Sounds like a problem with your slave cylinder or clutch master. Basically, the hydraulic system isn't disengaging the clutch enough. This could be air in the system, and this is the easiest (and least expensive) problem to solve. Simply bleed the clutch from the slave and also at the master cylinder. Bleeding at the master will require cracking the banjo bolt there and carefully protecting your paint from the fluid.
Old 11-25-2008 | 07:04 PM
drew_c14's Avatar
+1 on air
That's what it sounds like to me.
Old 11-25-2008 | 09:42 PM
wcavasos's Avatar
wcavasos is on a distinguished road
+2 sounds like a definate to me.
Old 11-26-2008 | 04:29 PM
ATLSHawk98's Avatar
ATLSHawk98
Thanks so much for the help! After fluid change/bleed everything is right back to normal. Flushed and bled the system at the slave and the banjo bolt and everything feels like brand new again!
Thanks again guys!
Old 11-26-2008 | 09:41 PM
Glad to be of service!
Red_Liner740
06-04-2009 01:47 AM
printdoctor
05-21-2007 04:18 PM
Philipian Ricer
09-15-2005 01:21 PM
mks8882
06-02-2005 12:04 AM
Philipian Ricer
02-06-2005 03:47 PM
