Chain & Sprockets suggestions?
#31
As for the $380, dealers charge what they can get. If you need a new chain and sprocekt and cannot do it yourself $380 might be cheap. I would never use a dealer except for machine work because I do not have a press or lathe, and tire changes because it is a PIA to do it yourself.
I like Silkolene chain lube for my street bikes. JB
#32
Well if you go 43 in the back, and keep 16 up front like I did, it will all go together much easier if you go +2 links. Stock is 102, so +2 is 104. I like this set up for street use. Unless you are racing around, get steel sprockets, they are stronger and last longer than aluminum, althogh they are heavier. I also replaced the rear sprocket drive cushions since it was all apart and they do harden after a while. I repaced the wheel bearings because I am OCD. I went with DID XRing and Sunstar since they are good quality, the other brands mentioned here are also good.
#33
My 2005, and the DID and Sunstar, it was a bit tight with 102 so I went with 104. You could get away with 102 and it would losen up to a good fit after a bit of riding.
SD Hawk
07-09-2009 09:48 AM
CNI Dawg
07-04-2007 05:19 PM
davidhartley
06-24-2007 03:16 PM
06, 1, 2, chain, forums, front, gold, gsx, pixtakeryahoocom, r600, rear, sprocket, stock, suggestion, suggestions
