CCT going out?
Old 04-16-2014 | 08:04 PM
Auron's Avatar
Auron
CCT going out?
This is for a 919 but since most Hondas from this era have CCT's go out I thought I'd give it a shot. The only thing that worries me is the rattle is the worst on left side and the CCT is on the right.
Old 04-16-2014 | 11:04 PM
jscobey's Avatar
could be a warn cam chain which means its loose and rattling around. im under the impression that CCT's dont "go out" slowly, but fail with a bang. but it could also be 50 other things. regardless id get it checked out before you ride it or even start it again. you dont want to do damage that can be prevented if u dont start it.
Old 04-17-2014 | 01:53 AM
Wicky's Avatar
+1 jscobey
Get it looked at!
Old 04-17-2014 | 03:23 AM
RoadManiac's Avatar
European Member
It sounds more like grinding gears, I hope for you that its only the starter clutch gear wich doesnt retract and grinds on the starter gear
Old 04-17-2014 | 08:11 AM
Auron's Avatar
Auron
The sound goes away above 3K, it just purrs The noise is only at idle and below 3K.
Old 04-17-2014 | 08:18 AM
jscobey's Avatar
why risk anything? have it looked at before it grenades. or nothing could happen and you could be fine. ill tell you for sure tho that engines shouldnt make any weird noises like that so whatever it is its not good. it might not be all that bad either, but its not suppose to be doing that
Crashrat
10-11-2012 09:25 PM
The Hawk Guy
05-14-2007 11:17 PM
malken00
12-03-2006 11:44 AM
dpenix76
09-18-2006 09:43 PM
bryantmvtr
08-23-2005 06:16 PM
