Carb tools. mixture screw
Hi
How the f... can i adjust the mixture screw on the carbs, impossible to get in there. tryed a million times now. getting fustrated :-(
I bought one of the cheap tools on ebay, but it cant go in there either.
So how do you guyes do it ?
Jens.
Jens.
Well that depends on what mixture screw you have... On the older models before they started mucking with legal stuff the carbs had a normal philips head type screw... Mine being a 97 has that, so all I need is an angled screwdriver, easily available in most hardware stores... That and some patience... (lots of it actually)
If your bike is a bit never the screws have a "D" shaped head, so then you either need to remove the airbox and such to remove the carbs and slot them prferably using a dremel or such so you can use a normal slot or philips head bit afterwards...
Or if you don't like tearings stuff apart and have deep pockets, buy this http://www.motionpro.com/motorcycle/partno/08-0229/ which has the "D" shaped bits...
