Carb Sync Tool
Carb Sync Tool
So, with the bike apart for the front end swap, I'm gonna do some of the important stuff before riding season.
I did a search of the web for Sync Tools.
Found this one:
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
Lots of pictures and good explanations of how they did it. Might try the 2 bottle method.
This might need to be moved and stickied for everyone's use??
Found this one:
I used the yardstick & tubes method, easy as pie.
FYI, several other similar threads - Carb Synch Tool Search
I believe the yard stick is the way to go if your looking to do it cheaply. Worked well for me many times. But I recently invested in the Motion Pro sync tool, very similar to the carbtune posted above.
mad skill collector
So the next logical question is did you notice if the yardstick was inaccurate?
As long as you get all of your air bubbles out, it's just as accurate as anything else. You're not trying to measure specific vacuum readings, you're trying to see if the vacuum from the two carbs is the same. So, if the liquid in the tubes (I used red Caterpillar coolant) rises at the same rate on both sides of the tube, you're good.
I also use one of these tools to adjust the carbs with.
http://www.motorcyclecarbs.com/kl/catalog/2003/069.pdf
No, there's nothing that "we" missed, some people would rather buy a gauge set. It would come in handy for recording vacuum readings for future use, or for synching four carbs without having to do them two at a time.
The yard stick and hose worked just fine. Mine only works on twins (although I have seen ones made for 4 cylinders) and isn't very professional looking. I have been between jobs for a while and have started to work on other peoples bikes, wheelers, sleds and such. That is why I spent the money on a proper tool. It has easily paid for itself.
I think gas would deteriorate the clear hose (and using black fuel line hose would defeat the purpose of the gauge) and would kinda stink. I used A/F because I had it on my shelf and it was red (easy to read).
is the oil moving fast or slow? if it is moving fast, insert a baffle into both ends of the tubing(i used 1 inch pieces of WD-40 spray tube) and this will slow it down so you can adjust easily. You may have to turn the idling up a little to get it to idle once you hook the tubing up. If the oil starts to move up on one side, simply turn the screw the other direction a hair. Make sure you are holding the throttle spring forward so the presssure you put on it to turn the adjuster isn't giving you a false reading. Just try to get the oil to stabilize, i.e., not moving up or down, and you'll be good. The adjustment is minute.
