Carb Sync question...
So I did a carb sync last weekend.
I used a home made manometer, and it worked great...idle only bounces now maybe 50rpm
My only question is...Since they wont sync perfectly at both idle and 4000 rpm...am I better off synching at idle, at 4000 rpm, or somewhere in-between?
Thanks,
Mike
Thanks,
Mike
It should be good...I originally synched at ~1200rpm, then after adjusting the throttle screw on the rear carb, I had to raise the idle a little bit.
So I wound up finishing the sync at ~1100-1150rpm...which is usually where I keep it.
I have read other posts about people having problems with their bikes dying at a lower idle setting, but I never had that problem since I got the bike 7 years ago.
Also, I would figure that 50-100 rpm shouldn't make that much of a difference as far as oil flow, but to be honest, I never really thought of that...so you bring up a good point, Resident.
I just always thought the bike sounded smoother and happier at 1100rpm.
Thanks,
Mike
Thanks,
Mike
just a thought, the two cylinders require different jetting for a reason, I imagine that the exhaust length has something to do with the scavenging effect, therefore the amount of vacuum that it pulls in the upper rpm. Set at idle, forget the rest.
bike, carb, carbs, carburator, carburetor, dying, honda, manometer, motorcycle, problems, sinc, superhawk, sync, vtr1000, wont
