Carb Sync
Old 04-19-2011 | 02:53 AM
1down5up's Avatar
1down5up is on a distinguished road
Carb Sync
Hi Guys,
When syncing the carbs is the adjustment screw/bolt located on the left hand side of the bike, infront of the rear cylinder facing forward?
If so, how the hell do you get in there. I can just get in there with an extention, a knuckle and a 7mm but its a pain in the ***.
Is there an easier way?
Old 04-19-2011 | 03:59 AM
jay956's Avatar
thats the way i do it, doesnt seem hard to me...
Old 04-19-2011 | 04:23 AM
1down5up's Avatar
i find the thermostat is in the way
Old 04-19-2011 | 08:04 AM
comedo's Avatar
I use a 1/4" drive extension, universal joint, 7 mm. socket and a good flashlight. I wrap the joint with a layer of electrical tape so the socket doesn't flop around as much. A Phillips head screw driver with a flexible shaft works too. The job gets easier with practice.
Old 04-19-2011 | 07:08 PM
fred's Avatar
Mid-level Member
fred
i've got a Motion Pro 90deg carb tool i picked up a long time ago for mucho bucks. i was using it with a 7mm socket the other day to sync my carbs. as i was squirming around, i managed to knock off the socket with the MP drive end. i spent a good hour with multiple flashlights trying to locate those precious items. good thing. in the process i noticed that i'd not placed the carb cooling hose clamp that sends coolant from the thermostat, and the hose end was weeping coolant.
remove tank, airbox, front cowl, unseat carbs. what fun. i found the MP end and socket down in between the cylinders. [man! it just started raining monsoon-style here!]
Old 04-20-2011 | 04:10 PM
There's a picture of it on my website. If I can get a pic of it with the tank on you sure as hell can get to it with a 7mm socket and an extension!
Old 04-20-2011 | 05:02 PM
RWhisen's Avatar
Former Superchicken Owner
I had no trouble getting to it with a 7mm offset wrench.
Old 04-20-2011 | 05:15 PM
dutchdude's Avatar
moto gp wannabe
dutchdude is on a distinguished road
Thanks for asking the question - i was looking at mine the other day and thinking the same thing. well i guess i have to stop thinking about now and just do it.
Old 05-28-2012 | 06:05 PM
WordTooYoMamma's Avatar
WordTooYoMamma is on a distinguished road
I just started the bike and stopped it several times to tweek the adjustment, each time I would turn the rear throttle adjustment clockwise so I could access the bolt, made my adjustments with a spanner wrench.
Old 05-28-2012 | 08:11 PM
1/4" drive driver handle (screw driver type) 3" extension, 1/4" drive U joint (wrap one layer of light tape around the u joint so it does not flop all the way over), 7mm socket. makes the task VERY easy.
Old 06-08-2012 | 04:40 PM
kum1ankka's Avatar
kum1ankka is on a distinguished road
I'm still in process of getting to syncing the carbs when I stumbled upon this thread. Have any of you guys tried if something like this works?
Flexible Driver for Hose Clamps - 10" (7mm Hex, ABA)
A flexible hose clamp driver with 7mm head if the link doesn't work or goes dead...
Old 06-08-2012 | 06:49 PM
Kind of, but with existing tools.
Craftsmen 1//4" stuff
7mm socket
2" extension
2" flex drive extension
1/4 drive driver handle
all but the flex drive come in even the most basic Craftsmen 1/4" drive set.
Old 06-08-2012 | 07:18 PM
I personally don't like the flex drives as they tend to "wind up" and then turn to far.
Also lifting the rear of the tank slightly makes the adjustment much easier.
Old 06-08-2012 | 07:36 PM
True if using them for a fastener that is tight, but on the carb screw that only takes a ftlb or 2 to turn it's a non issue.. or at least is with the tools I use.
I also use a 1/4 drive U joint with a wrap of electrical tape to limit "flop".
Both setups work well for me.
Dave Wicks
06-21-2008 07:56 AM
reaper
09-22-2007 11:15 AM
VTRFISH
08-16-2005 11:57 AM
mikecronis
05-26-2005 09:10 PM
cozart02
04-14-2005 07:31 PM
