Carb issues?
Old 06-27-2009 | 12:28 PM
dschreins's Avatar
dschreins is on a distinguished road
Carb issues?
I have a 1999 Superhawk, that everytime i hit the brakes hard it will die, regardless of how long its been running for. Also when it is hot and i'm not traveling very fast it will start to die. i have no idea whats wrong. suggestions?
Old 06-27-2009 | 01:23 PM
chickenstrip's Avatar
chickenstrip
Die as in cut out immediately? Or sputter to stop?
Some typical problems people have are poorly routed gas tank venting tubes, and improperly installed vacuum tubes coming off the rear of the petcock. Something to check but from your description sounds like something else. Are you losing electrical power when this happens?
Old 06-27-2009 | 02:33 PM
dschreins's Avatar
It dies immediately, but the electrical is still going. almost as if it ran out of gas. which would lead me to possibly believe its dirty carbs and the sludge is sliding around, so when the bike goes to stop hard is gives the illusion of being out of gas?
There's a fix for this on my website. Click the link in my sig.
Old 06-28-2009 | 07:20 PM
dschreins's Avatar
where in your site can I find that?
Old 06-28-2009 | 07:44 PM
under:
VTR1000F -> Performance and Mods -> VTR Carb Fix
Old 06-28-2009 | 08:54 PM
Thanks lazn!
Old 07-22-2009 | 07:41 PM
dondiggdy's Avatar
dondiggdy is on a distinguished road
I HAD THAT PROBLEM I WOULD CHECK YOUR AIRFILTER, IF IT IS CLOGGED THIS COULD CAUSE THE BIKE TO DIE ALSO CHECK YOUR BATTERY A WEAK BATTERY,BAD PLUGS, COULD ALSO BE THE PROBLEM DIRTY CARBS ETC...
Old 07-22-2009 | 09:27 PM
yellerhawk's Avatar
yellerhawk is on a distinguished road
had the same problem. found it was a melted wire in the loom for the kick stand safty. shorted out on turns and hard braking
Bdalefire115
09-18-2012 01:41 PM
rideAK
04-16-2011 11:13 AM
uchi
08-16-2010 12:28 PM
shamper
04-17-2008 05:37 AM
Erion_squid
02-20-2007 01:28 AM
