Buell footpegs, anyone?
Hello, everyone. I'm new to the forum and new to the VTR, though I've been lurking for a while.
Anyway, shortly after I purchased the bike I decided I wanted more legroom. I'd heard of people adapting Buell XB12S Lightning footpegs http://www.buell.com/en_us/gear/acce...ProductID=1941 to other bikes, but I couldn't find anyone here using them. I purchased a pair (around $25 at the local H-D dealer) and modified them to fit my Super Hawk. They fit fine with a bit of grinding and the use of a couple of bushings and the extra inch or so of legroom was great. However, due to my size 13 feet and my Jardine high-mount exhaust, I can't use them unless I want my shoes melted.
So, the question is, does anyone want to try my set of modified Buell pegs? They'll fit the stock mounts with no modifications to the bike, but they hang low enough that they probably won't work with the stock exhaust. They may work well with other high-mount systems or if your feet are smaller than mine.
Here's the deal. I'll ship you the pegs and bushings free of charge. If you like them, send me $30. If you don't, ship them back to me or to another forum member. I'm not particularly concerned what happens to them. I'm just curious as to whether they'll work for someone else. Send me a PM if you're interested.
-Aaron
-Aaron
Why
-Aaron
-Aaron
I realize the stock exhaust runs inboard of the mounts, but there must be a bolt on the other side. On my bike, the rubber isolators were still in the mounting holes below the pegs. The Buell pegs were against the isolators. I've never seen the stock exhaust, but I have to think that would cause interference issues.
-Aaron
-Aaron
Did someone else take the pegs?
-Aaron
-Aaron
I saw 2 or 3 similar but different styles of Buell 1" lower footpegs. I was thinking, instead of using bushings due to the larger Buell bolt diameter, why not weld up the holes and drill them back out to the Honda diameter?
Nope. They aren't welded in, so yes, I could have them welded up. (I'm not a welder) Don't really need to though, as the steel bushings appear to be a good fit, and should wear well. I put the left one on when I dropped by the house for lunch. It fits, but does lightly contact the washer under the bolt head for the exhaust mount. I can further clearance the peg, which I'll want to do anyway, as they it is still angled upward slightly, so that should solve that problem. Looking at it from the back of the bike, the left peg (the buell) is certainly lower than the honda one on the right, not to mention that there is not rubber pad on there which makes the OEM one taller. I'll try and take some pictures of it to show the relative difference.
-R
-R
Right on! Let me know what you find out when you do that bar conversion. I could be interested in that; even with helibars, I could always stand to sit more upright. I love the standard seating position of my bandit. The legroom on the SH is already much much much better than on the TL-S I used to have.
-R
-R
Yeah, I kind of left the pegs unfinished. I got them to fit, but didn't go any further due to the clearance issues with my heels and the exhaust. I figured if I really liked them, I'd consider buying another set and refining the fit (maybe welding them rather than bushing them, as a previous poster suggested). I'd be concerned about removing too much metal, though, as they are just lightweight cast aluminum. Anyway, they really seem like they could be a good setup for the right bike or rider.
-R
-R
Check some of the threads by superbling on his bar mods. Drag bars will work. We exchanged some PM's and he had a bandit before the hawk and I rode a friends bandit and found the ergos perfect.
I'm interested in this buell footpeg mod. Please post some pics.
Pegs are on, and I finally got the motor done last night (see CCT thread for that) so...this morning was my first ride on the new pegs. First impressions are pretty good. They are a little more slippery than the stockers, being polished aluminum, but the position is great. I need to take apart the brake m/c for the rear and adjust that pedal down. Looks like I can just remove that locknut and get plenty more adjustment...getting the whole thing apart looks like a bit of a pain though. Oh well. All in good time. I will try and post the pics I took the other day...just been side tracked with lots of work and other projects. As far as difference, it looks to me to be about a 1.5" drop or so, BUT they move back about an inch too, and are sloped more downward that the stock pegs (which is preferable IMO). Anyway...so far so good.
-R
-R
1 of 100
Our old friend and resident round eye in Nippon Stu Ablett (now VTRless but always another project underway) had a lil guy who was making them for a fancy track school (I bow with eyes up for them using VTRs) after a year of cajoling produced a LE of 100. Don't know how many went to what country but could ask him. Thin tubing and light welds made for a couple reinforcements (HT braze) but tidey design. I have designed 3 times mod to permit removal of crank plug w/o left removal (PITA) but not executed 1. Very light but requires repair after hard kiss. Yet uneploited for DL or alt peg attchmt. More pics & i-instructions pos
Ummmm. Uhh.... thanks?
I understood about 1/3 of that post... but you should definitely post up some more pics...
I ground my new buell pegs and put them on tonight. No bushings though. I cannot locate any that fit. I'm wondering how necessary they really are since when the pegs are down they don't move...opinions?
I think that I adjusted my brake pedal all the way down and I still have to lift my foot off the peg to use the rear brake...not good. If I cannot find any more room I'll have to go back to stock.
Adjusted the shifter. At first it was too far and for some reason I couldn't use first. Fiddled with it until I could get first, but some more adjustment is in order.
I'm riding it to work tommorrow as-is. I'll make adjustments in the parking lot during work (one of the benefits of having a boss that is an hour away and spread too thin).
Should I worry about bushings or not?
I got my bushings at Sears Hardware. I found them in one of the bins in the fastener department. Of course, I had to drill the pegs to fit the bushings, but the pins fit almost perfectly inside the bushings.
How did you adjust the brake pedal? Mine appears to be adjusted all the way down, but is still too high. I had a delivery truck pull out in front of me this morning and when I went to hit the rear brake it wasn't there...not cool.
Yes, Install Bushings
wyldryce said: I need to take apart the brake m/c for the rear and adjust that pedal down. Looks like I can just remove that locknut and get plenty more adjustment...getting the whole thing apart looks like a bit of a pain though.
I put mine on a couple of weeks ago. A friend made bushings for me.
first shifter adjustment, I also couldn't shift all the way into first. Backed off a bit and it is okay, but a bit higher than my first choice.
Haven't done the brake yet.
I'm wondering if my boot soles will get melted. The buell pegs move as far back as down. My heel seem to be right on the pipe.
I may try the other peg lowering trick from superbling using ZXR9 pegs through the exhaust mount hole.
Miles of Smiles
Tom
Miles of Smiles
Tom
Fiddled with it more in the parking lot...
Shifter seems fine new. Right where I want it and it goes into all the gears.
I've adjusted the brake as far as the stopnut allows. I think on Sunday (riding tomorrow) I'll take the stopnut off, grind 1/8 inch off the bolt, and put a thinner stopnut on. If that desn't get me there, I'll have to bend it.
My size 12's do rest on the cans. I always touched the cans and would rest on them while highway riding. Now my boots will touch all the time. I don't think it will be a problem, but tommorrow's ride will tell for certain.
I'll report back later this weekend on how well these pegs do. I'm hoping my hips and knees won't ache after ~300mi day. The other thing that genuinely concerns me is the peg feelers seem very long. I don't want to take them off, but may find a better (shorter) substitute.
Post Ride Update
I finally got things where I want them yesterday as far as pedal adjustment and put a ride in today.
I spent a total of 9 hours on the bike today. Well on, and off if you include lunch and gas stops. This definetly helped as far as my aching knees and hips. I was still sore when the day as done, but not "soak in the hot tub" sore. More of a managable like sitting at my workdesk allday sore.
My second biggest concern was that the pegs would grind. No problem. I think it actually helped force my butt off the seat and concentrate on smooth instead of jerking it into the turn and hammer the throttle on exit. Not that I did that before either.
All in all I'll give this mod a 7/10 for function and an 8/10 for ease. 10/10 for price since it was under $30 total. Never did put the bushings in, and I probably won't.
