Bucking Hawk
Old 08-05-2008 | 08:48 PM
kenhawk's Avatar
Junior Member For Now
kenhawk is on a distinguished road
Bucking Hawk
Just got a 98 hawk with the magic 31k miles on it!!!!!
It bucks often under 3k at a steady speed...
I fear its the CCTS and this sucks!!!
What do you all think it could be?
I know people talk about changing at this milage with the manual APE? CCTS.
What is the cost from the dealer to have this done?
Thanks!
Ken
Old 08-05-2008 | 08:52 PM
Thumper's Avatar
Do you by chance think the bucking sensation is actually a back fire into the air box?
Old 08-05-2008 | 08:53 PM
MisfitToy's Avatar
Shredding Asphalt
mine does the same thing... before and after I adjusted my manual CCT's as well as checking valves. I juct chocked it up to one of those quirks. the only thing I havent done yet it sync carbs... so if you do and it goes away let me know. I just downshift and ride up around 4grand
Old 08-05-2008 | 08:56 PM
MisfitToy's Avatar
Shredding Asphalt
its not an upward bucking sensation if hes talking about what mine does, I think he is. More like a cylinder didn't fire. it possibly could be timing but I think it would happen every time if it was... mine just happens every once and awhile. But it was made worst by reversing pair valves. no idea their..
Old 08-05-2008 | 10:08 PM
If its only below 3k rpm, mine has been doing that since it was new...driveline surge. These bikes run pretty lean at idle and low rpm with stock carb settings. An ignition misfire is more likely under load.
Try downshifting to bring the rpm's up. If the bucking goes away don't worry about it, or have the carbs looked at if it bothers you. Mine runs flawlessly over 3k.
Paso Robles? You've got some great roads up there. What are you running under 3k rpm for?
Old 08-05-2008 | 10:31 PM
RK1's Avatar
RK1
Could be a few different things but I think most likely improperly set up carbs.
Don't see how it could be CCTs. CCTs serve only one purpose- to keep the cam chains on. If they're on ( and everything else is OK) the bike runs fine. If they're off it doesn't run at all.
Old 08-06-2008 | 12:26 AM
jbaxx's Avatar
Honducati
You are lean. This is common if you have slip on exhaust and have not rejetted.
Old 08-06-2008 | 07:18 AM
timdske's Avatar
timdske is on a distinguished road
Mine will do it as well. It seems to do it more when it's colder outside and I going slowly through town. It's always done it, I was told it was due to the motor running too lean at the lower rpm's. It goes away at the higher speeds.
It's nothing to worry about. It's one of the many quarks of owning a Superhawk.
Old 08-06-2008 | 07:22 AM
FTMS's Avatar
It sounds like a lean and possibly needing a carb sync.
Old 08-06-2008 | 09:59 AM
jbaxx's Avatar
Honducati
It's not a "quirk". You need to rejet and sync the carbs. Do it and your bike will run great!
Old 08-06-2008 | 10:50 AM
Thumper's Avatar
+1
Mine never does this, Jardines, K$N, Factory Pro Jet kit dialed in correctly for my bike and elevation
Old 08-06-2008 | 05:23 PM
shayne's Avatar
+1
+2
Some tuning can remove this problem. My bike does not do it now.
Old 08-07-2008 | 08:10 AM
kenhawk's Avatar
Okay I feel much much better! I just bought it used so I dont know if it did it from day one. It has yoshi pipes and rejetted from the previous owner.
THANKS AGAIN!
Ken
Old 08-07-2008 | 09:25 AM
Death Cattle's Avatar
do you have a full tank¿ haha
Old 08-22-2008 | 12:40 PM
996er's Avatar
996er is on a distinguished road
Get some seafoam in the tank and see if it clears up. I bought mine wrecked and had been sitting for a year and a half or so. I fgured it was the carbs so put about a half a cans worth of seafoam in the gas about two tanks worth and it runs like a champ ever since! I've got her up to just shy of 160mph without a stutter or hesitation...
Old 08-22-2008 | 12:44 PM
Syclone's Avatar
Boosted
Originally Posted by shayne
+2
+3
Mine did this when I got it, but I've since adjusted carbs.
Old 08-22-2008 | 10:34 PM
zerocool's Avatar
zerocool is on a distinguished road
your problem could be slack in the cam chain like you mentioned. i dont have a twin but 954. but a lot oof my bikes lurching went away with the ape. there is slack in the drive chain which always causes a little buck. slack in the cam chain will do it too (even just a bit)
Old 08-22-2008 | 10:36 PM
zerocool's Avatar
the combination of 1 to 2 inches of slack in your drive chain plus an improperly slacked cam chain (worn out honda tensioner). can definitely cause some extra yankage
Old 08-24-2008 | 08:10 AM
gboezio's Avatar
If you have a dynojet kit drop the needle clip one notch lower, if you have a stocker shim the needle (pull the needle away from the seat) It will stop to fart in the intake
Old 08-24-2008 | 09:10 PM
kenhawk's Avatar
Well I guess I will find out soon enough.
I think the CCT went last week. I am going to build a platform to pull the front head off and see what damage there is. See my other post about either breaking the chain or cct in the front cylinder.
rob...
03-26-2013 03:06 PM
BiG_hUsS
11-03-2009 05:06 PM
CentralCoaster
09-13-2008 01:51 AM
powderun
03-23-2007 10:18 AM
zimm
01-12-2007 04:01 PM
