Bike won't start after sitting
The title pretty much says it all... I let my bike sit for a few of our triple-digit months and now it won't start and stay running. It ran fine when I parked it. The battery is charged and it pops like it wants to run, but won't stay running for more than a couple of cycles. What's more likely... gummed up carbs or bad gas?
Both, and add plugged pilot jet(s) to the list. Pump gas can go bad in just a few weeks, and can turn to sludge just as quick depending on the additive package.. Worse when you have high temps and it increase the evap rate.
Seems like it was just some bad fuel in the float bowls. I was going to take the carbs out but decided to try draining them first instead. A little more fresh fuel in the tank and the carbochicken roared back to life.
I've twice now had to put the battery on the charger for a few minutes because I couldn't get it to start after letting it sit for like 2 weeks. At this point, I'm thinking the 10% ethanol gas I'm using is separating, and won't start because all it gets initially is ethanol. Does anyone else notice the bike not starting as quick as it should when you let it sit for a week or two?
Also, I seem to have misplaced my factory service manual. I probably left it at the guy's house where I did my forks. Anyway, could someone briefly describe how to drain the float bowls, please? I don't like the idea of letting this fuel sit in there for more than a day or two now.
(On a related note, I will no longer buy motorcycle gas at Sheetz because their ethanol content is up at 15%.)
On a side note, Sheetz gas is complete junk. Many of my friends cars' injectors get really loud just aftter running a few tanks of their gas through the engine. As an early present, I got a $25 gift card for Sheetz. And I can tell you right now that I will be buying there good food, not their gas with that card too!!!
...and don't forget to clean your spark plugs as they are likely fuel-fouled from the repeated starting attempts.
cel2620xl
03-04-2011 05:03 PM
