bike shuts down on its own
ok so i know the problem..sort of...my magnetic starter fuse keeps popping and im wondering if its the regulator, the converter unit, the magnetic starter itself, or maybe the ign. modual...can someone please help before i buy all of these parts for nothing.
My bet is Regulator, same symptom my had when regulator went bad. Search the forum, you should find numerous hits on this and discussions on which regulator to purchase as a replacement instead of the OEM VTR unit.
read and follow the info on this thread,you will be good to go.
the bottom line,get a 5 wire mosfet rectifier ,and you will be good to go.
https://www.superhawkforum.com/forum...why-how-25117/
Honestly, find a chunk of 15 minutes in your day an read through the first posts in that thread by tweety (MOSFET R/R one). It answers these questions and more and you'll be able to answer future ones without feeling in the dark. There's a lot of info, so it looks overwhelming so if you still have questions ask them, because there's not a one word answer to either.
-R1 is better than R6, but some fit better than others.
-Year specifically does not matter, but the newer ones are more likely to be MOSFET.
To make it easy, post #6 has a list of the best replacements.
SgtRon
07-23-2014 08:01 AM
