Bent or warped front left rotor....
Ok, so I am pretty sure that the front left is not so straight....lol....The front brakes pulse when I stop, so I jacked the front end up, and try to spin the tire/wheel....not so much, barley moves free, it is hard to spin....so I eyeball the rotor to the caliper looks slightly warped.....so my question is.....
I probably have excess ware on that pad? right? so I guess I will be replacing the rotor and the pads.....
so anyone got a straight one they wanna sell/give me cheap???? Hey I am on a tight budget.....
Also, is it true that if you are riding hard on the brakes, and the rotors heat up, and you hold the brakes at a stop light etc... will the heat warp or bend the rotors???? does that make sense??
Shew, TIA
Shew, TIA
