Banjo fitting size 10mmX?
If I'm not too confused (It happens a lot!) I'm guessing you are referring to the dimensions of the thread, ie thread pitch? M10x1.00 or M10x1.25 ?
The VTR uses M10x1.25 on the stock banjo bolts...
fitting
Nope, not the bolt/threads ect. tweety.
looking for the specs on the fitting at the ends of the lines.
As far as I know all have a 10mm dia. opening bu I need to dubble check the thickness "flat to flat"
The stock spec would be nice.
heres the deal. I have the ability and certified equipment to make
U.S. DOT CERTIFIED brake and clutch lines. I am looking to order some SS fittings to make up new lines for my hawk. In that didn't want to open my brake system just to get the measurement, then wait to get the fittings and make up the lines.
Banjo fittings and their perspective bolts kind'a come as a "matched pair". The cross drilled "flow" holes in the bolt should center in the fitting. The point being that if someone uses aftermarket lines that differ from stock but are using the original bolts they may be hindering the system.
I believe the fitting is a 10mm X 10mm (hole dia. X thickness) but just tring to get confirmation
