APE rear cct oil leak
My rear APE cct leaks oil at the adjuster bolt threads. I read a thread from 2007 from Hawkrider about a fix and I was hoping to get some more info on how to do it. I am going for 9 days in the Alps in Sept. and don`t want to have oil all over on the trip. Any help will be appreciated. Mark
Do what's necessary, so you can back the bolt out out about 1/4"-3/8". Then apply some thread sealant to the threads. Then all you have to do is screw the bolt back in. Adjust as necessary.
Edit: E. Marquez got back to ya while I was writing mine.
Does it leak that much that you dont want to ride 9 days with it like that? It should leak, but only a drop or two a day. I backed my out, wrapped it with teflon tape (plumbers tape) and put it back in, no leaks since.
Crashrat
10-11-2012 09:25 PM
