ape cct install
Old 04-06-2006 | 04:03 AM
denmah's Avatar
denmah
ape cct install
i know its been talked about, and i did some searching, but is there anyting special you need to do while swapping out stock for ape's?
and what is the correct way to adjust tension on the screw?
my bike has 18k on it and im looking to install the manual CCT's very soon.
im assuming you can just remove the stock ones, and toss on the aftermarket, tighten them up and your fine?
thanks.
Old 04-06-2006 | 02:38 PM
NOrrTH's Avatar
Re: ape cct install
You didn't search very hard. This topic, and other important topics are in the "Knowledge Base"
https://www.superhawkforum.com/viewtopic.php?t=2038
Old 04-06-2006 | 04:08 PM
Loco's Avatar
Loco
pwned
Old 04-06-2006 | 05:53 PM
denmah's Avatar
denmah
i did see that topic, and it has no proceedure, nore does it answer my simple questions.
pwned.
Old 04-06-2006 | 06:06 PM
NOrrTH's Avatar
Re: ape cct install
Ok my bad lol
Its not as simple as a straight re and re
The engine has to be at TDC for each piston to remove the old ones so as to remove them without tension. Setting the tension on the APE's is measured at the cam chain between the two cam gears at 1/4 inch, or was it 1/8th? total slack. There are instructions on the back of the APE package but then erroneously say 1/4 inch "deflection", which is just down and not total slack. They may have changed it after our phone call.
There is another link around with these instructions.
Old 04-07-2006 | 08:35 AM
EngineNoO9's Avatar
on that it said that ape cct's cause more wear and that the newer cct by honda has the problem fixed... so is the consensus to still use the manual ones or what? I'm nearing 17k soon and will be at 20k come summer... I'd much prefer to do this as preventative then have it break on me...
Old 04-07-2006 | 09:22 AM
Randman's Avatar
Moderate-whore
Re: ape cct install
I am with you on that one.....course is it just miles, or do years play a part....mine is a 99' but only has 6200 miles on her, I put 1200 in the last 4 months....So should I even be thinking about those at this time??? Hmm....
Old 04-07-2006 | 02:40 PM
Vincent's Avatar
Vincent
Re: ape cct install
Yeah, I was wondering that too and can't seem to find info anywhere. Is there a difference in the years? Did they fix the design at some point? Mine is an '04 with just over 5k miles, but I would rather prevent a problem than have damage after failure.
Old 04-07-2006 | 03:12 PM
denmah's Avatar
denmah
hmm i guess i will have to contact a dealer, see if they know anything about it, and also order the new honda replacements.
Old 04-07-2006 | 03:50 PM
NOrrTH's Avatar
Re: ape cct install
I just did the valves/shims the other day and checked the APE CCT's and am happy to report that they did not need any readjustment at all after one year 10k kms.
Old 04-16-2006 | 01:52 AM
The spring man's Avatar
The spring man
I would refer to my ads for springs and have long think about why manual adjusters are already not an option used by Honda? in SP1 or 2? I dont profess to be the oracle on VTRs or indeed any make of machine, but which modern motorcyle opts to use a nut and bolt to tighten its cam chain? i would be interested to know.
Cheers
Dave
SloBlue
09-08-2013 07:19 AM
dannyz
09-04-2010 06:11 AM
99Hawkboy
08-19-2006 02:06 PM
NOrrTH
08-15-2005 09:20 AM
AZZKIKER
04-12-2005 10:04 PM
