Anybody use a bigger battery?
Old 04-17-2005 | 10:15 AM
VTRumble's Avatar
I need a new battery and noticed that the next size up (12v14) would give another 20 CCA and is only 5/8" taller - otherwise the same size. It looks like it would work, and I don't see any down side to it. Has anybody done it?
Doug O
Old 04-17-2005 | 04:39 PM
caffeineracer's Avatar
caffeineracer
Re: Anybody use a bigger battery?
Doug O
sounds like a good idea. battery may last longer too.
it's mounted on an angle so it needs to be a sealed type battery.
make sure the pos/neg terminals will be in the right locations,
enough lenght on the cables to reach the higher batt terminals,
will have to modifiy the battery cover,
other than that just clearance for the taller bat.
Let us know how it works.
I've had good luck with WestCo batterys sent to my house in a couple days
~Jeffers
Old 04-18-2005 | 05:04 AM
VTRumble's Avatar
WestCo is who I was going to go through. It's an AGM battery so no worry about leaking. I'll let you know how it turns out.
Doug O.
Old 04-18-2005 | 05:49 AM
Shmittay's Avatar
Shmittay
Once when my battery died, I pulled the battery from my CBR and put it in the VTR. It was the same size length and width, but a bit taller. It worked, but the battery cover that is supposed to snap closed didnt. I dont remember how much taller it was than the hawk battery, but I remember there being not a whole lot of room in order to get that cover sealed. I ended up having to trim a bit off of the top of it. Hopefully 5/8" wont be as big a problem though.
ur_averagejoe4
05-24-2012 09:25 AM
skycam
10-24-2010 12:40 AM
smokinjoe73
05-19-2010 11:23 AM
V-king
12-26-2009 01:57 AM
Wolverine
06-21-2009 02:38 PM
