any one replace the glass in clutch cover?
Old 07-15-2008 | 10:52 AM
codfish124's Avatar
SuperCock roster
codfish124 is an unknown quantity at this point
can it be done i found a clutch cover but the glass is broken mine is ok can i swap them or what???
Old 07-15-2008 | 11:33 AM
divingindaytona's Avatar
Remember stock is BAD!
Talking
I would not want to use glass for a clutch cover.
Look at the damage you just did to your magnisium covers.
Old 07-15-2008 | 11:53 AM
codfish124's Avatar
SuperCock roster
nonono the glass oil check thing
Old 07-15-2008 | 12:02 PM
superbling's Avatar
He's yanking your............ cod piece.
Never heard of anyone switching out the sight glass.
Old 07-15-2008 | 08:20 PM
peterpanic's Avatar
pragmatic anarchist
Honestly, not to be a smartass, but whenever a "can it be done" question like this comes up I always point out that the things are originally made from ground up and melted rocks dug out of the earth, so yes!!! it CAN be done, the question you are dealing with is how easily and what are your other options. Take a real good look at how that glass is held in there. I'd check mine out but it's dark and my bike is mostly together right now so I'd only be able to see the outside. If it is held in by pressed aluminum (magnesium, uranium?) around it you have a challenge but o-rings or rubber or adhesive seals might not be too tough to replicate. You could even fab up a plug with a dipstick in it. Best of luck.
Old 07-15-2008 | 08:36 PM
Have you tried removing the broken one to see how it's held in there? I have a brand new one I looked at. I really don't care to frig with it but there's a rubber gasket around it on the inside so it certainly appears to come out. Also take a look on ronayers.com see if it's in the microfiche.
Old 07-15-2008 | 09:39 PM
doggerman's Avatar
doggerman is on a distinguished road
new to the supercock world
thats the first time I've heard or seen that.Why did'nt I think of it.
Old 07-16-2008 | 05:54 AM
codfish124's Avatar
SuperCock roster
it can be done did it last night. its not to hard but really didnt want to brake the glass i just pryes the old one out by the back metal thing and taped it in with a 13/16 no leaks yet
CrickiKaze
03-19-2014 01:06 AM
Crashrat
10-11-2012 09:25 PM
Vincent
06-30-2011 01:58 PM
5150
06-08-2009 07:01 PM
yellowvtwin
01-29-2006 09:02 AM
