alot of work ahead
alot of work ahead
ok,i have been stocking up on parts for a bit know.been limping the bike along until i have enough stuff to do a good run thru on the bike.
my first question is,i have racetech springs and rebound and compression valves,seals,everything for the forks except a brace.
what fork oil should i be using in the rebuild.
bike is stock and i weight 175 if that helps any.
the front end will all be done up,changing bearings too,any little tips on that would help too.
so we both will be learning together lol
It's pretty straight forward. Best advice is to have a clean work bench, take your time and keep all parts clean at all times. Loosen Forks cap before you remove the forks. Becareful removing the allen head bolt on the bottom of the forks. make sure when you install the fork seal everything is super clean.
Good luck, it's a nice day long projec, if it's your first time.
yes,this is first time.i will not be doing it today,still waiting on other parts.im gonna do one big run thru on the bike,from screws,to carbs,seals,bearings etc etc....i have alot of parts.
the body will be the last thing.
i will attempt to do the forks myself,but,we have a resident suspension guy,so if i get in trouble,i will be able to take it to him.
Another tip... Before you loosen the fork caps, also loosen the allen bolt in the bottom of the forks... Don't remove it, it will leak oil, but loosen it... If you try to do it in the other order, it will probably just spin... A real PITA... I's much, much easier to get both parts moving before you drop the forklegs... Will probably spill a few drops, but it's well worth it...
so would anybody know what weight fork oil i should use.
i will be doing this very soon,in the next couple of days.
from what i have researched,140mm is a good starting point or does it really depend on other factors.
well,today is the day,been working on the bike the last couple of days,got alot done.
so does everyone agree with 5w oil and 130mm
the bike most likely wont see track days,but i do ride it hard at times.
so would this be correct to go with.
