Air Cut Off Valve
Old 05-19-2008 | 01:36 PM
1baddoggie's Avatar
1baddoggie is on a distinguished road
Air Cut Off Valve
I have been troubleshooting my deceleration popping and was wondering if anyone has every tested the air cut off valve? Engine braking (the manual calls it) popping out the exhaust is cause by a too lean condition and the air cut off valve is suppose to cut the air supply to the pilot system at some given level of vacuum thereby richening it for that condition. The manual does not state what vacuum point it should close/open.
The bike configuration;
2 Bros slip on
PAIR valves have been blanked off
All emission removed (CA)
It has stock jetting
I have checked for air leaks and that seems good
I pulled the carbs a second time to check everything over and looked at the air cut off valves, that is when I came to the issue of being able to check them accurately.
Thanks
Old 05-19-2008 | 02:21 PM
RCVTR's Avatar
My 49 state bike didn't have air cutoff valves. when I put 2 bros slip-ons on it I started to have lean decel popping. A #45 pilot jet was the cure.
Old 05-19-2008 | 02:51 PM
drew_c14's Avatar
This might be a stupid question, but...
When you removed the pair you did block off the vacuum ports right?
Old 05-19-2008 | 04:53 PM
There is a procedure in the manual for checking them, though it doesn't give a specific vacuum spec for it.
Old 05-19-2008 | 06:03 PM
1baddoggie's Avatar
Yes, and the one for the Evap system.
Old 05-19-2008 | 06:07 PM
1baddoggie's Avatar
Yes, kinda odd since they do give it for testing the PAIR valve. You would want it to engage and dis-engage at the right vacuum points...you'd think...
1bd
Old 05-19-2008 | 06:15 PM
1baddoggie's Avatar
#45 is the stock pilot jet. You are saying you went up a size on the pilot and that cured it?
The Last Gunfighter
05-18-2014 07:48 PM
shwinny
05-21-2011 03:48 AM
LeanRider
06-12-2007 10:42 AM
klicks
11-20-2006 03:46 PM
CNI Dawg
11-16-2005 11:07 PM
