Aftermarket ISR clutch/brake master cylinder
Has anyone tried replacing thier Clutch's master cylinder? I want the clutch to engagement point to be adjustable, so the clutch grabs about halfway between pulled in and relased. My clutch engages when the clutch lever is almost all the way relased.
Am I looking at the right thing?
What diameter handlebars do I have?
2001 Superhawk
2001 Superhawk
I believe that last link from www.shopxr.com does NOT come with a master cylinder. I think the master cylinder is what I am having an issue with.
It WILL work... The VTR bars are 22 mm (7/8" = 22.22mm) It's a Clutch OR Brake radial MC...
Ie you can just as easily use it for the clutch as the brake...
The only real difference in a stock item is that they are designed for left/right side use... this is modular, so you put the mount together in a different way depending on which side it's going on....
The other item is a matching lever for a cable operated clutch, wich you won't need...
The down side might be though if you wan't matching item's is that you then need 2 of them... And that will cost you a very pretty penny...
You're sure you won't just learn to live with the quirks of having a hydraulic clutch?
Oh btw thi link gives you all the item's at shopxr... http://www.shopxr.com/showproduct.as...0976&aid=10050
The MC is still 463$ and the 204$ is the cable operated one...
What about searching for a replacement lever that is adjustable instead of the entire assem?
Does anyone know if 929/954/RC levers are a direct swap w/ the super hawks?
I feel like finding a replacement lever would be your cheapest way to get adjustment on engagement point. Unless you're also looking for a bigger bore MC.
This might be the ghetto way, but couldn't you just file/grind a bit away on the lever where if contacts the piston for the MC.... you might need to add a very light spring in there someway to keep the lever from rattling when your off the clutch... but this seems like something that could be fixed/modded for less than 500 dollars.
J.
J.
I'm looking at a radial clutch MC right now with a 19mm piston with M10 x 1.25 banjo. Do you think it'd work okay?
Thanks,
RC
