adding driving lights to a '98
Old 08-17-2010 | 08:59 PM
osage kid's Avatar
osage kid is on a distinguished road
I hate riding at night (deer country) but would still like the option.
In a perfect world, I would turn night into day with a flip of my GOD switch and dim the windshields of oncoming traffic instead of being dazzled to blindness through my faceshield by every oncoming semi.
I'm sure someone somewhere has thought of this or even tried it, but I can't seem to find the right way to search for old threads.
First, I know I need to work with the amount of power my alternator puts out before adding auxiliary lights. How much does the bike make stock, and are there non-stupid ways to upgrade it?
Here's the idea. Install rearview mirrors with integrated turnsignals, then mount some serious driving lights using the fairing ports where the old turnsignals were before the mirror swap.
Are the turnsignal mounts adequate to hold a heavier light?
Has anyone tried something similar, and what were the results: ugly bike, fried electricals, etc?
TIA
Old 08-17-2010 | 09:07 PM
Why not do it the smart way... Bi-xenon HID projector... Then you don't need driving lights... Trust me on that...
Old 08-17-2010 | 09:09 PM
RWhisen's Avatar
Former Superchicken Owner
Your biggest hurdle will be to overcome the charging system limitations
Old 08-17-2010 | 11:27 PM
lukenukem47's Avatar
with the hid and all led everywhere else will there be a problem with the charging system keeping up?
Old 08-18-2010 | 05:28 AM
Actually a HID draws less than stock, 35W vs 55/65W of the stock H4 bulb... So does the LED's... So in the end you put less total load on the system, but unfortunately you are now putting greater load on the R/R to get rid of the excess as heat... You could use that to add driving lights as well if you really like...
BTW when I talk about HID I talk about a projector, retrofitted into the housing... Absolutely not a HID H4 bulb whatever kit dropped into the stock reflector... It's not even close in performance... More light, but mostly in the wrong place... And depending on the aim it could actually casue an accident, blinding an oncoming driver...
Old 08-18-2010 | 08:53 AM
uchi's Avatar
gotta agree with tweety, i did an fxr projector with bulb and ballast for like 175 bucks. took me an hour to put it together. and its incredible. night time riding is no longer an issue
this is my low bea, lighting up the fence in my backyard
Old 08-18-2010 | 02:07 PM
Mattaua's Avatar
Mattaua is on a distinguished road
previous owner of my sh hooked up driving lights. they work great but pretty much monthly I end up with bulbs burning out.
Old 08-18-2010 | 02:53 PM
That could be either the wrong voltage levels, bad grounding, ecessive heat buildup or vibration... Neither are a good thing for bulbs...
Old 08-30-2010 | 07:42 PM
CANADAVTR's Avatar
CANADAVTR is on a distinguished road
Hi Uchi, how are you?...
Can you tell me more about the headlight conversion? And any ideas for the daytime running light (above the headlight)...mine looks like a candle!
Cheers...John
Old 11-16-2010 | 08:51 AM
richterat83's Avatar
Light Whore
richterat83 is on a distinguished road
I dont' have my bike yet, but would one of these fit if you cut up the back of the "third eye"?
http://www.oznium.com/high-intensity...otlight/photos
rafbo
01-03-2019 03:38 PM
NOrrTH
01-15-2010 09:47 AM
Hotbrakes
11-20-2007 02:50 PM
Condor
11-08-2007 07:33 PM
spEEdfrEEk
07-01-2004 05:51 AM
