98 vtr NOT running smooth now..
Old 04-16-2008 | 09:50 AM
speedhawk's Avatar
One Wheel Wonder
speedhawk is on a distinguished road
Question 98 vtr NOT running smooth now..
I got my carb boots in yesterday and i no longer have an intermident missfire!!! bike ran 25 minutes and had no failure, then i did it again. nothing.. which is good!
however, dispite the great news that my problem seems to be fixed, now my bike is running TERRIBLE!! its idles very rough like the cylinders are running different.
im going to take a stab and say the carbs need to be adjusted and/or synchronized?? i messed a little bit with the idle adjustments for both, and i could smooth it a little bit but then it was running bad at higher RPMs. i noticed that when i reved it a bit the slides were moving back and forth very hard. After that, i reinstalled the air box to see if that made a difference. maybe a little bit? it was hard to tell.
well, ill say something is probably out of adjustment because i disonected the throttle cable and moved those carbs all over the place to get those boots on
can anyone that knows more than me about our VTRs help me out? maybe its a quick fix. im not too good with carburation...
Old 04-16-2008 | 07:24 PM
...Idle adjustment for BOTH carbs??? There is only ONE idle adjustment. If you were messing with two screws then you were adjusting synchonization, and now it definitely needs to be synced. Also, check that you hooked everything back up correctly - vacuum line to BACK of petcock, PAIR hoses installed correctly if still in use, TPS connector connected, airbox seated fully, etc.
Old 04-17-2008 | 07:53 AM
speedhawk's Avatar
One Wheel Wonder
thanks greg. ill jump back into it tonight and check everything you said. i DO want to make sure about that vacume line thats supposed to be on the back of the carb
Old 04-17-2008 | 09:46 PM
speedhawk's Avatar
One Wheel Wonder
well... all the lines are correct. today, it actually seems to be running much better. i dont know why. but it is still not as good as it was before i tore the bike down to replace carb boots. is it just my carb sync?
when i take off easy, it sputters a little bit, sounds like its running on one cyclinder a little bit. i am pretty sure it feels like one cyclinder running faster than the other? not 100% sure though.
As i go down the street, and get on it a little bit, it clears up pretty nice.
When i let off of the throttle, it spitters and sputters again, way worse than it used to when i didnt have any problems!! i rode 8000 miles over last summer, i dont think i forgot the amount it does that when i let off. i know it is slightly the nature of the bike but its way worse than it was now.
COULD this be carb sync? i dont have the tools to do it
Old 04-18-2008 | 01:20 AM
I assume you replaced the intake boots becuase of an air leak...? If so were the carbs sync'd while there was a leak? If so, then they were sync'd with compensation for the intake leak... They will have to be re-sync'd. A carb sync on a VTR is a rather simple procedure that can be done without removing any body panels or even flipping up the gas tank. I can't imagine that your local dealership would charge you more than an hours labor for it.
Old 04-18-2008 | 05:39 AM
drew_c14's Avatar
Check the ohms on the TPS too.
Old 04-18-2008 | 05:30 PM
speedhawk's Avatar
One Wheel Wonder
FIXED!!! i syncd up today with a sync at work i found. been out riding this afternoon!! im happy. runs good, all back together and polished up. new tires, full tank of gas.. feels good having it running when it hasnt been for the last 4 months!!
Thanks everyone for all the help. hope i can return the favor.
vinkate
02-14-2012 04:06 PM
Wattz187
04-23-2011 03:21 PM
J Bragg
02-04-2011 07:32 PM
SS_Will
10-14-2008 12:14 PM
someonehappy
02-27-2006 03:34 PM
